跳转到主内容
Samsung Galaxy Tab 3 7.0 3G Battery Replacement
你所需要的
视频概述
  1. Samsung Galaxy Tab 3 7.0 3G Battery Replacement, White Backing: 步骤 1 中的图像 1,3 Samsung Galaxy Tab 3 7.0 3G Battery Replacement, White Backing: 步骤 1 中的图像 2,3 Samsung Galaxy Tab 3 7.0 3G Battery Replacement, White Backing: 步骤 1 中的图像 3,3
    • To begin working on your repair, turn your device over and open the micro SD slot, as shown in the first picture.
    • Using the flat part of the spudger, begin pushing it between the white backing and the SD slot. Continue to pry off the white backing until you hear several clicks and see the white backing lift up, as shown in the second picture.
    • Continue to pry off the white backing around the device, as shown in the third picture.
  2. Samsung Galaxy Tab 3 7.0 3G Battery Replacement: 步骤 2 中的图像 1,1
    • Once the backing has been pried off all around the device, remove the white backing.
  3. Samsung Galaxy Tab 3 7.0 3G Battery Replacement, Silver Siding: 步骤 3 中的图像 1,3 Samsung Galaxy Tab 3 7.0 3G Battery Replacement, Silver Siding: 步骤 3 中的图像 2,3 Samsung Galaxy Tab 3 7.0 3G Battery Replacement, Silver Siding: 步骤 3 中的图像 3,3
    • To remove the silver siding, begin by pushing the spudger between the frame and the screen, as shown in the first picture.
    • Do this until you see the silver siding begin to lift up. Continue doing this around the edges of the device, as shown in the second picture.
    • Once you silver siding is loose all around the device, remove it carefully with your hand as shown in the third picture.
  4. Samsung Galaxy Tab 3 7.0 3G Battery Replacement, Battery: 步骤 4 中的图像 1,3 Samsung Galaxy Tab 3 7.0 3G Battery Replacement, Battery: 步骤 4 中的图像 2,3 Samsung Galaxy Tab 3 7.0 3G Battery Replacement, Battery: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Begin by removing the four designated 1.33x2.00 mm Phillips screws with the screwdriver, as shown in the first picture.
    • Once the screws are removed, use a pair of tweezers or the spudger to remove the battery connector.
    • Pull the battery connector up as shown in the second picture.
    • Once the battery connector is removed, you can remove the battery using the spudger as shown in the third picture.
结论
7等其他人完成本指南。
Andrea Flores
于10/09/14注册
1,516 声望
创作了6篇指南
团队
Cal Poly, Team 14-30, Maness Fall 2014 Cal Poly, Team 14-30, Maness Fall 2014 的会员
CPSU-MANESS-F14S14G30
4 名成员
创作了18篇指南
3条评论
Thanks for this guide. It was really helpful. I did not need to remove the silver siding to replace the battery. Is this step optional?
Mark
mrbaker1917 - 回复
I am glad this was useful mrbaker1917!! Yes, removing the silver sliding is optional but useful if you are trying to replace anything else on your tablet.
Andrea Flores - 回复
Good job Andrea!
AT&T told us to buy a new tablet; couldn't get batteries anymore. Usual no-nothing big box store employees selling on commission.......sheeesh!
You're the hero today!
Rock
good medicine - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 37
总计 17,542
