跳转到主内容
Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement
你所需要的
  1. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement, Rear Case: 步骤 1 中的图像 1,2 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Insert an opening pick between the rear case and the plastic rim.
    • You may need to add multiple picks to detach the clips.
    • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
    • Continue to slide the pick around the edge of the rear case until all clips are released.
  2. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 步骤 2 中的图像 2,2
    • Lift the case up to remove it.
  3. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement, Battery: 步骤 3 中的图像 1,3 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement, Battery: 步骤 3 中的图像 2,3 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement, Battery: 步骤 3 中的图像 3,3
    • Use the flat end of a nlyon spudger to pry up the black plastic tabs securing the two ZIF connectors.
  4. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 步骤 4 中的图像 2,2
    • Use the flat end of a nylon spudger to pry up the brown plastic tab securing the orange ribbon cable.
  5. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 步骤 5 中的图像 3,3
    • Remove all three ribbon cables by gently pulling the cables away from the ZIF connectors.
  6. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 步骤 6 中的图像 1,1
    • Use a Phillips #000 screwdriver to remove the ten 3mm screws securing the battery to the chassis.
  7. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 步骤 7 中的图像 1,2 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 步骤 7 中的图像 2,2
    • Use the pointed end of a nylon spudger to pry the two battery connections away from the motherboard.
  8. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 步骤 8 中的图像 1,2 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 步骤 8 中的图像 2,2
    • Lift with a nylon spudger to remove the battery.
  9. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement, Motherboard: 步骤 9 中的图像 1,2 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement, Motherboard: 步骤 9 中的图像 2,2
    • Insert an opening pick between the plastic frame and the screen.
    • Slide the opening pick around the perimeter of the screen.
    • You will hear clicking noises as each plastic clip is released from the display chassis.
  10. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 步骤 10 中的图像 1,1
    • Lift the plastic frame to remove.
    • Avoid the three delicate ribbon cables.
  11. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 步骤 11 中的图像 1,1
    • Use a Phillips #000 screwdriver to remove the 3mm screw attaching the motherboard to the display chassis.
  12. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 步骤 12 中的图像 1,3 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 步骤 12 中的图像 2,3 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 步骤 12 中的图像 3,3
    • Use a nylon spudger to flip up the eight press-fit connectors from the motherboard.
    • The vibration motor is missing from these photos.
  13. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 步骤 13 中的图像 1,2 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 步骤 13 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use nylon-tipped tweezers to remove the motherboard.
  14. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement, Speaker & Auxiliary Port: 步骤 14 中的图像 1,2 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement, Speaker & Auxiliary Port: 步骤 14 中的图像 2,2
    • Using the pointed end of a nylon spudger, pry upwards between the screen chassis and the auxiliary port.
    • The speaker is permanently connected to the auxiliary port and will need to be removed from the device as a single unit.
  15. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 步骤 15 中的图像 1,2 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 步骤 15 中的图像 2,2
    • Use the flat end of a spudger to pry upwards between the speaker and the display chassis.
    • Remove the speaker and auxiliary port assembly.
  16. Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 步骤 16 中的图像 1,2 Samsung Galaxy Tab 3 10.1 Speaker & Auxiliary Port Replacement: 步骤 16 中的图像 2,2
    • Use the pointed end of a spudger to pry upwards between the other speaker unit and the display chassis.
结论
另外一个人完成了本指南。
Corey Brown
于06/24/16注册
8,688 声望
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 1,372
