跳转到主内容
Samsung Galaxy Tab 3 10.1 Rear Case Replacement
你所需要的
  1. Samsung Galaxy Tab 3 10.1 Rear Case Replacement, Rear Case: 步骤 1 中的图像 1,2 Samsung Galaxy Tab 3 10.1 Rear Case Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Insert an opening pick between the rear case and the plastic rim.
    • You may need to add multiple picks to detach the clips.
    • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
    • Continue to slide the pick around the edge of the rear case until all clips are released.
  2. Samsung Galaxy Tab 3 10.1 Rear Case Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Tab 3 10.1 Rear Case Replacement: 步骤 2 中的图像 2,2
    • Lift the case up to remove it.
结论
2等其他人完成本指南。
Corey Brown
于06/24/16注册
8,670 声望
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 1,853
