本指南有最近更改,您可查看未经巡查的最新版本。
你所需要的
Insert an opening pick between the rear case and the plastic rim.
Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
Continue to slide the pick around the edge of the rear case until all clips are released.
Use the flat end of a nlyon spudger to pry up the black plastic tabs securing the two ZIF connectors.
Insert an opening pick between the plastic frame and the screen.
Slide the opening pick around the perimeter of the screen.
12等其他人完成本指南。
3条评论
Great guide, project completed.
Simplemente GENIAL!!!!
Muy claro.
Felicitaciones.
Cuenten con mis aportes al foro
Ahora que pude retirar placa base voy a ver esquemático, porque WIFI se desactiva . No funciona.
Saludos
