跳转到主内容
Samsung Galaxy Tab 3 10.1 Motherboard Replacement
你所需要的
  1. Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Rear Case: 步骤 1 中的图像 1,2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Insert an opening pick between the rear case and the plastic rim.
    • You may need to add multiple picks to detach the clips.
    • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
    • Continue to slide the pick around the edge of the rear case until all clips are released.
  2. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Lift the case up to remove it.
  3. Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Battery: 步骤 3 中的图像 1,3 Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Battery: 步骤 3 中的图像 2,3 Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Battery: 步骤 3 中的图像 3,3
    • Use the flat end of a nlyon spudger to pry up the black plastic tabs securing the two ZIF connectors.
  4. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Use the flat end of a nylon spudger to pry up the brown plastic tab securing the orange ribbon cable.
  5. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 步骤 5 中的图像 3,3
    • Remove all three ribbon cables by gently pulling the cables away from the ZIF connectors.
  6. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Use a Phillips #000 screwdriver to remove the ten 3mm screws securing the battery to the chassis.
  7. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 步骤 7 中的图像 1,2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Use the pointed end of a nylon spudger to pry the two battery connections away from the motherboard.
  8. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 步骤 8 中的图像 1,2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Lift with a nylon spudger to remove the battery.
  9. Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement, Motherboard: 步骤 9 中的图像 2,2
    • Insert an opening pick between the plastic frame and the screen.
    • Slide the opening pick around the perimeter of the screen.
    • You will hear clicking noises as each plastic clip is released from the display chassis.
  10. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Lift the plastic frame to remove.
    • Avoid the three delicate ribbon cables.
  11. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Use a Phillips #000 screwdriver to remove the 3mm screw attaching the motherboard to the display chassis.
  12. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 步骤 12 中的图像 1,3 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 步骤 12 中的图像 2,3 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 步骤 12 中的图像 3,3
    • Use a nylon spudger to flip up the eight press-fit connectors from the motherboard.
    • The vibration motor is missing from these photos.
  13. Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 步骤 13 中的图像 1,2 Samsung Galaxy Tab 3 10.1 Motherboard Replacement: 步骤 13 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use nylon-tipped tweezers to remove the motherboard.
结论
12等其他人完成本指南。
Corey Brown
于06/24/16注册
8,826 声望
创作了11篇指南
3条评论
Great guide, project completed.
Edgar Merced - 回复
Simplemente GENIAL!!!!
Muy claro.
Felicitaciones.
Cuenten con mis aportes al foro
Ahora que pude retirar placa base voy a ver esquemático, porque WIFI se desactiva . No funciona.
Saludos
DARIO GASTAUDO - 回复
very easy to destroy the Galaxy. finicky to the max!
ein Stein - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 48
总计 9,714
