跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Tab 3 10.1 LED Light Replacement
你所需要的
    1. Samsung Galaxy Tab 3 10.1 LED Light Replacement, Rear Case: 步骤 1 中的图像 1,2 Samsung Galaxy Tab 3 10.1 LED Light Replacement, Rear Case: 步骤 1 中的图像 2,2
      • Insert an opening pick between the rear case and the plastic rim.
      • You may need to add multiple picks to detach the clips.
      • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
      • Continue to slide the pick around the edge of the rear case until all clips are released.
      添加评论
    2. Samsung Galaxy Tab 3 10.1 LED Light Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Tab 3 10.1 LED Light Replacement: 步骤 2 中的图像 2,2
      • Lift the case up to remove it.
      添加评论
    1. Samsung Galaxy Tab 3 10.1 LED Light Replacement, LED Light: 步骤 3 中的图像 1,2 Samsung Galaxy Tab 3 10.1 LED Light Replacement, LED Light: 步骤 3 中的图像 2,2
      • Insert an opening pick between the plastic frame and the screen.
      • Slide the opening pick around the perimeter of the screen.
      • You will hear clicking noises as each plastic clip is released from the display chassis.
      询问修复机器人
      添加评论
    2. Samsung Galaxy Tab 3 10.1 LED Light Replacement: 步骤 4 中的图像 1,1
      • Lift the plastic frame to remove.
      • Avoid the three delicate ribbon cables.
      询问修复机器人
      添加评论
    3. Samsung Galaxy Tab 3 10.1 LED Light Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy Tab 3 10.1 LED Light Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy Tab 3 10.1 LED Light Replacement: 步骤 5 中的图像 3,3
      在这个步骤中使用的工具:
      • Use the flat end of the spudger to flip up the press-fit connector attaching the LED to the motherboard.
      • Remove the LED indicator light by gently pulling upward with nylon-tipped tweezers.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
6等其他人完成本指南。
Corey Brown
于06/24/16注册
9,448 声望
创作了11篇指南
1指南评论
Above article is useful for removing LED Light.
Which LED are we removing - Camera Flash or screen display LED?
How to fit new LED Light?
Please reply. I am facing issues with screen display and flash for camera is also not working
Ashwini Dughad - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 42
总计 4,987
