跳转到主内容
Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement
你所需要的
  1. Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement, Rear Case: 步骤 1 中的图像 1,2 Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Insert an opening pick between the rear case and the plastic rim.
    • You may need to add multiple picks to detach the clips.
    • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
    • Continue to slide the pick around the edge of the rear case until all clips are released.
  2. Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement: 步骤 2 中的图像 2,2
    • Lift the case up to remove it.
  3. Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement, Front-Facing Camera: 步骤 3 中的图像 1,1
    • Lift the plastic frame to remove.
    • Avoid the three delicate ribbon cables.
  4. Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use the flat end of a plastic spudger to pry up the press-fit connector from the motherboard.
    • Remove the camera by gently pulling upward with a pair of tweezers.
结论
2等其他人完成本指南。
Corey Brown
于06/24/16注册
8,826 声望
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 7
总计 876
