跳转到主内容
Samsung Galaxy Tab 3 10.1 Battery Replacement
你所需要的
  1. Samsung Galaxy Tab 3 10.1 Battery Replacement, Rear Case: 步骤 1 中的图像 1,2 Samsung Galaxy Tab 3 10.1 Battery Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Insert an opening pick between the rear case and the plastic rim.
    • You may need to add multiple picks to detach the clips.
    • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
    • Continue to slide the pick around the edge of the rear case until all clips are released.
  2. Samsung Galaxy Tab 3 10.1 Battery Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Tab 3 10.1 Battery Replacement: 步骤 2 中的图像 2,2
    • Lift the case up to remove it.
  3. Samsung Galaxy Tab 3 10.1 Battery Replacement, Battery: 步骤 3 中的图像 1,3 Samsung Galaxy Tab 3 10.1 Battery Replacement, Battery: 步骤 3 中的图像 2,3 Samsung Galaxy Tab 3 10.1 Battery Replacement, Battery: 步骤 3 中的图像 3,3
    • Use the flat end of a nlyon spudger to pry up the black plastic tabs securing the two ZIF connectors.
  4. Samsung Galaxy Tab 3 10.1 Battery Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Tab 3 10.1 Battery Replacement: 步骤 4 中的图像 2,2
    • Use the flat end of a nylon spudger to pry up the brown plastic tab securing the orange ribbon cable.
  5. Samsung Galaxy Tab 3 10.1 Battery Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy Tab 3 10.1 Battery Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy Tab 3 10.1 Battery Replacement: 步骤 5 中的图像 3,3
    • Remove all three ribbon cables by gently pulling the cables away from the ZIF connectors.
  6. Samsung Galaxy Tab 3 10.1 Battery Replacement: 步骤 6 中的图像 1,1
    • Use a Phillips #000 screwdriver to remove the ten 3mm screws securing the battery to the chassis.
  7. Samsung Galaxy Tab 3 10.1 Battery Replacement: 步骤 7 中的图像 1,2 Samsung Galaxy Tab 3 10.1 Battery Replacement: 步骤 7 中的图像 2,2
    • Use the pointed end of a nylon spudger to pry the two battery connections away from the motherboard.
  8. Samsung Galaxy Tab 3 10.1 Battery Replacement: 步骤 8 中的图像 1,2 Samsung Galaxy Tab 3 10.1 Battery Replacement: 步骤 8 中的图像 2,2
    • Lift with a nylon spudger to remove the battery.
结论
75等其他人完成本指南。
Corey Brown
于06/24/16注册
8,826 声望
创作了11篇指南
7条评论
Great, Thanks for the help. It was very useful.
nyhorseracing - 回复
why are there white lines all over the screen after a new battery was installed
Rosita Fowler - 回复
brilliant ! worked extremely well !
Carmelo Aquilina - 回复
Thank you very much for the information. I have one question, though. The new battery works, but it takes a VERY long time to charge. More than a day, in fact. Any idea what could be causing that? Is it possible that one of the connections is not tight enough? If so, which connection might that be?
Thank you.
Paul Ross - 回复
Very easy instructions. Thank you. My only snag was that the ten screws holding the battery were extremely reluctant to undo. wrecked the IFxit screw driver. Fortunately, I had another one. My tip for anyone doing this little job, is to use quit a lot of downward pressure on the screws. Turn them 1/4 turn anticlockwise and back again. Do this several times until they turn freely. You will then have an easy job. I will replace those screws with a tiny blob of 'Never Seize'.
Keith Aldworth - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 46
过去 30 天: 265
总计 43,549
