跳转到主内容
Samsung Galaxy Tab 3 10.1 Battery Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Samsung Galaxy Tab 3 10.1 Battery Replacement, Open Device: 步骤 1 中的图像 1,1
    • Using your plastic opening tools, carefully start to pry apart your Samsung Galaxy Tab 3 10.1 all along the edge. Do this until the back side of the tablet can be removed.
    • Be careful when inserting the opening tools to avoid damaging the speakers on left and right sides. The picture actually show a dangerous position for the right (small) opening tool.
    • During reassembly, be careful not to insert bottom, left, nor right edges first—doing so can damage the power button, and prevent the front panel from sitting totally flush.
    • If screen is cracked like shown imagine, Place tape on screen to prevent injury.
  2. Samsung Galaxy Tab 3 10.1 Battery Replacement, Ribbon Cables: 步骤 2 中的图像 1,1
    • Gently remove tape over ribbon cable connectors and set it to the side. Using the opening tools, gently lift the connector latches to disconnect the ribbon cables.
  3. Samsung Galaxy Tab 3 10.1 Battery Replacement, Battery Screws: 步骤 3 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the ten screws securing the battery to the motherboard.
    • Make sure to keep screws in a secure location for reassembly.
  4. Samsung Galaxy Tab 3 10.1 Battery Replacement, Removal: 步骤 4 中的图像 1,1
    • Pull back the ribbon cables, lift up the original battery, and disconnect the battery by exerting upward pressure from beneath the battery.
结论
45等其他人完成本指南。
Fabio
于10/16/14注册
1,506 声望
撰写一个指南
团队
UMass Dartmouth, Team 2-2, Duarte Fall 2014 UMass Dartmouth, Team 2-2, Duarte Fall 2014 的会员
UMASSD-DUARTE-F14S2G2
4 名成员
创作了6篇指南
4条评论
is there a diference between the lte, 3g and wifi versions of the samsung tablet
Josh Robinson - 回复
thanks for the information. i will use it wisely.
Adelle Bradley - 回复
Battery changed, works fine !
Thank you for the tuto :-)
Sharky Billy - 回复
Great guide thank you.
My cover is not flush, even though I carefully attached the top first then downwards - I'm just clumsy I guess.
George Cooke - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 54,399
