此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
简介
转到步骤 1 ↓使用本指南更换 Samsung Galaxy Tab 3 10.1 平板电脑的电池。
你所需要的
要重新组装设备,请按相反顺序执行这些说明。
77等其他人完成本指南。
7指南评论
Great, Thanks for the help. It was very useful.
why are there white lines all over the screen after a new battery was installed
brilliant ! worked extremely well !
Thank you very much for the information. I have one question, though. The new battery works, but it takes a VERY long time to charge. More than a day, in fact. Any idea what could be causing that? Is it possible that one of the connections is not tight enough? If so, which connection might that be?
Thank you.
Very easy instructions. Thank you. My only snag was that the ten screws holding the battery were extremely reluctant to undo. wrecked the IFxit screw driver. Fortunately, I had another one. My tip for anyone doing this little job, is to use quit a lot of downward pressure on the screws. Turn them 1/4 turn anticlockwise and back again. Do this several times until they turn freely. You will then have an easy job. I will replace those screws with a tiny blob of 'Never Seize'.
