跳转到主内容
Samsung Galaxy Tab 2 7.0 Camera Replacement
你所需要的
  1. Samsung Galaxy Tab 2 7.0 Camera Replacement, Camera: 步骤 1 中的图像 1,1
    • Using a nylon spudger or a flat plastic opening tool, pry open the back of the device.
    • It is easiest to begin this process by starting at the micro SD card insert, as shown in the pictures.
  2. Samsung Galaxy Tab 2 7.0 Camera Replacement: 步骤 2 中的图像 1,1
    • Using a phillips head screwdriver, remove the 6 4mm screws holding the battery on the device.
    • Remove the battery, and set it aside.
  3. Samsung Galaxy Tab 2 7.0 Camera Replacement: 步骤 3 中的图像 1,1
    • Using a phillips head screwdriver, remove the 6 4mm screws holding the motherboard in the device.
  4. Samsung Galaxy Tab 2 7.0 Camera Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy Tab 2 7.0 Camera Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy Tab 2 7.0 Camera Replacement: 步骤 4 中的图像 3,3
    • Locate the 8 flex cables attached to the motherboard.
    • Using a nylon spudger, gently detach each flex cable from the motherboard.
    • Be careful when detaching flex cables. Excessive force and sharp objects have the potential to damage these components.
    • Lift the motherboard from the device and set it aside.
  5. Samsung Galaxy Tab 2 7.0 Camera Replacement: 步骤 5 中的图像 1,1
    • Locate the camera towards the top of the device.
    • Use a nylon spudger to gently lift the camera and remove it from the device.
结论
2等其他人完成本指南。
Katija Tarailo
于03/02/17注册
460 声望
创作了3篇指南
团队
IUPUI, Team S3-G1, Harley Spring 2017 IUPUI, Team S3-G1, Harley Spring 2017 的会员
IUPUI-HARLEY-S17S3G1
4 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 722
