跳转到主内容
Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement
你所需要的
  1. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement, Auxiliary Port: 步骤 1 中的图像 1,1
    • Using a nylon spudger or flat plastic opening tool, pry open the back of the device.
    • It is easy to begin this process by starting at the micro SD card insert.
  2. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips head screwdriver, remove the 6 4mm screws holding holding the battery on the device.
  3. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: 步骤 3 中的图像 3,3
    • Gently detach the set of wires clips connecting the battery to the device using a nylon spudger.
    • Remove the battery and set it aside.
  4. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: 步骤 4 中的图像 1,1
    • Using a Phillips head screwdriver, remove the 6 4mm screws holding the motherboard in the device.
  5. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: 步骤 5 中的图像 3,3
    • Locate the flex cables attached to the motherboard. Using a nylon spudger, gently detach each flex cable from the motherboard.
    • Be careful when detaching flex cables. Excessive force and sharp tools have the potential to damage these components.
    • Lift the motherboard from the device and set it aside.
  6. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: 步骤 6 中的图像 3,3
    • Locate the yellow brackets at the bottom of the device.
    • Using a phillips head screwdriver, remove the single 4mm screw on each bracket, located on either side of the auxiliary port.
    • Lift the brackets from the device and set them aside.
    • You may need to use a nylon spudger, or any flat tool, to lift the brackets out of their place.
  7. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: 步骤 7 中的图像 1,1
    • Using a nylon spudger, or any flat tool, gently pry and lift the small metal covering off of the auxiliary port.
    • This will reveal a rubber covering.
  8. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: 步骤 8 中的图像 1,1
    • Using a nylon spudger, or any flat tool, gently pry and lift the small rubber covering to expose the auxiliary port.
    • This will reveal the auxiliary port.
  9. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: 步骤 9 中的图像 1,1
    • Lift the auxiliary port with a nylon spudger.
    • Remove the auxiliary component.
    • It is easiest to lift this piece from the innermost side of the port, opposite of the opening.
结论
5等其他人完成本指南。
Katija Tarailo
于03/02/17注册
460 声望
创作了3篇指南
团队
IUPUI, Team S3-G1, Harley Spring 2017 IUPUI, Team S3-G1, Harley Spring 2017 的会员
IUPUI-HARLEY-S17S3G1
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 18
总计 2,017
