跳转到主内容
Samsung Galaxy Tab 2 10.1 Headphone Jack Replacement
你所需要的
  1. Samsung Galaxy Tab 2 10.1 Headphone Jack Replacement, Back Cover: 步骤 1 中的图像 1,2 Samsung Galaxy Tab 2 10.1 Headphone Jack Replacement, Back Cover: 步骤 1 中的图像 2,2
    • The plastic opening tool may break during this step. You may need to use the heavy duty spudger instead.
    • Insert the plastic opening tool between the glass screen and the back cover so the curved end of the plastic opening tool is under the glass. Gently pry the back cover away from the glass screen.
    • Be sure to lift the entire display from the body and that you are not are lifting the glass from the display. You will need to reach down a little further for the correct removal.
    • Continue inserting the plastic opening tool around the whole device screen to completely separate the back cover from the glass screen.
  2. Samsung Galaxy Tab 2 10.1 Headphone Jack Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Tab 2 10.1 Headphone Jack Replacement: 步骤 2 中的图像 2,2
    • Gently lift the screen up with your finger.
    • If the screen will not separate from the back cover, try repeating step 1.
  3. Samsung Galaxy Tab 2 10.1 Headphone Jack Replacement, Battery Disconnect: 步骤 3 中的图像 1,1
    • Using your fingers, remove the green tape covering the battery connector.
  4. Samsung Galaxy Tab 2 10.1 Headphone Jack Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy Tab 2 10.1 Headphone Jack Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy Tab 2 10.1 Headphone Jack Replacement: 步骤 4 中的图像 3,3
    • Insert the flat end of the heavy-duty spudger between the wires and underneath the battery connector. Carefully lift the black battery connector up to disconnect it from the motherboard.
    • The metal spudger shown in the photo is not recommended due to the possibility of an electrical short. Use an ESD-safe tool, such as a heavy-duty (nylon) spudger.
  5. Samsung Galaxy Tab 2 10.1 Headphone Jack Replacement, Headphone Jack: 步骤 5 中的图像 1,2 Samsung Galaxy Tab 2 10.1 Headphone Jack Replacement, Headphone Jack: 步骤 5 中的图像 2,2
    • Unscrew the two 3mm screws with the Phillips 000 screwdriver.
  6. Samsung Galaxy Tab 2 10.1 Headphone Jack Replacement: 步骤 6 中的图像 1,1
    • Lift the black cable connector with the plastic opening tool to disconnect the cable from the device.
  7. Samsung Galaxy Tab 2 10.1 Headphone Jack Replacement: 步骤 7 中的图像 1,1
    • Slide the flat end of heavy-duty spudger under the audio jack cover and lift up to remove the metal cover from the device.
  8. Samsung Galaxy Tab 2 10.1 Headphone Jack Replacement: 步骤 8 中的图像 1,1
    • Insert the flat end of the heavy-duty spudger under the headphone jack and gently lift up to remove the headphone jack from the device.
结论
6等其他人完成本指南。
Amy Tsai
于01/30/15注册
1,977 声望
创作了2篇指南
团队
Cal Poly, Team 6-26, Amido Winter 2015 Cal Poly, Team 6-26, Amido Winter 2015 的会员
CPSU-AMIDO-W15S6G26
5 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 3,587
