跳转到主内容
Samsung Galaxy Star Pro Motherboard Replacement
你所需要的
  1. Samsung Galaxy Star Pro Motherboard Replacement, Battery Replacement: 步骤 1 中的图像 1,1
    • Place phone firmly between both hands with one hand flat on the back of the phone and pop off the back cover
  2. Samsung Galaxy Star Pro Motherboard Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Star Pro Motherboard Replacement: 步骤 2 中的图像 2,2
    • Once rear cover is off use small pastic spudger to lift battery out of the phone
  3. Samsung Galaxy Star Pro Motherboard Replacement, Screen: 步骤 3 中的图像 1,1
    • After following how to remove the battery, unscrew the five 1.2mm Phillips Screws on the one back of the phone using screw driver. Use the J00 Phillips head screw bit to take out the screws
  4. Samsung Galaxy Star Pro Motherboard Replacement: 步骤 4 中的图像 1,1
    • Once screws are removed turn the phone over and use the plastic opening tool and unclip the connector holding the screen to the motherboard.
    • Be careful to not damage the press-fit connector that connects the screen to the motherboard.
  5. Samsung Galaxy Star Pro Motherboard Replacement: 步骤 5 中的图像 1,1
    • Us the plastic opening tool to pry apart the screen from the plastic. Start from one side and work your way around the whole phone.
  6. Samsung Galaxy Star Pro Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,2 Samsung Galaxy Star Pro Motherboard Replacement, Motherboard: 步骤 6 中的图像 2,2
    • Unscrew the 1.2mm Phillip screw that connects the motherboard to the rest of the phone. Then by using your thumbs pop the inners of the phone out. Also use same J00 Phillips head bit from prior steps.
结论
3等其他人完成本指南。
Kevin Teque
于03/10/16注册
294 声望
创作了2篇指南
团队
UMass Dartmouth, Team 7-2, Catania Spring 2016 UMass Dartmouth, Team 7-2, Catania Spring 2016 的会员
UMASSD-CATANIA-S16S7G2
3 名成员
创作了5篇指南
2条评论
more information please....
me good - 回复
What information are you looking for?
Kelsea Weber -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 3,124
