跳转到主内容
Samsung Galaxy SIII Mini VE Volume Button Replacement
你所需要的
  1. Samsung Galaxy SIII Mini VE Volume Button Replacement, Removing Rear Casing: 步骤 1 中的图像 1,3 Samsung Galaxy SIII Mini VE Volume Button Replacement, Removing Rear Casing: 步骤 1 中的图像 2,3 Samsung Galaxy SIII Mini VE Volume Button Replacement, Removing Rear Casing: 步骤 1 中的图像 3,3
    • Flip your phone so you are facing the back.
    • Locate the notch at the top and gently use your finger or an opening tool to remove the rear casing.
  2. Samsung Galaxy SIII Mini VE Volume Button Replacement, Removing Battery: 步骤 2 中的图像 1,2 Samsung Galaxy SIII Mini VE Volume Button Replacement, Removing Battery: 步骤 2 中的图像 2,2
    • Use your finger or an opening tool to pry the battery out of the phone.
  3. Samsung Galaxy SIII Mini VE Volume Button Replacement, Removing Screws: 步骤 3 中的图像 1,1
    • Use the Phillips #000 Screwdriver to remove the 10, 4mm screws holding the plastic frame in place.
  4. Samsung Galaxy SIII Mini VE Volume Button Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy SIII Mini VE Volume Button Replacement: 步骤 4 中的图像 2,2
    • Using an opening tool, gently separate the plastic framing from the phone.
  5. Samsung Galaxy SIII Mini VE Volume Button Replacement, Removing Circuit Board: 步骤 5 中的图像 1,3 Samsung Galaxy SIII Mini VE Volume Button Replacement, Removing Circuit Board: 步骤 5 中的图像 2,3 Samsung Galaxy SIII Mini VE Volume Button Replacement, Removing Circuit Board: 步骤 5 中的图像 3,3
    • Unhook the two electrical connections at the bottom of the phone using your fingernail or a spudger.
    • Next, use the spudger and tweezers to remove the speaker at the top of the phone.
    • Once the 3 components have detached, the circuit board should release from the phone except for 1 connection on the underside.
    • Detach this connection using the spudger.
  6. Samsung Galaxy SIII Mini VE Volume Button Replacement, Removing Volume Button: 步骤 6 中的图像 1,2 Samsung Galaxy SIII Mini VE Volume Button Replacement, Removing Volume Button: 步骤 6 中的图像 2,2
    • Locate the volume button.
    • Using the tweezers, life the volume button up and away from the phone.
结论
3等其他人完成本指南。
Megan
于10/23/14注册
1,186 声望
创作了6篇指南
团队
Michigan Tech, Team 1-8, Lauer Fall 2014 Michigan Tech, Team 1-8, Lauer Fall 2014 的会员
MTU-LAUER-F14S1G8
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 12
总计 904
