跳转到主内容
Samsung Galaxy SIII Mini VE Battery Replacement
你所需要的
  1. Samsung Galaxy SIII Mini VE Battery Replacement, Removing Rear Casing: 步骤 1 中的图像 1,3 Samsung Galaxy SIII Mini VE Battery Replacement, Removing Rear Casing: 步骤 1 中的图像 2,3 Samsung Galaxy SIII Mini VE Battery Replacement, Removing Rear Casing: 步骤 1 中的图像 3,3
    • Flip the phone over so you are viewing the back.
    • Using you fingernail, or an opening tool, pry open the notch that is located at the top of the phone.
    • Carefully follow you finger or opening tool around the edge of the rear casing until it has detached from the phone.
    • Set the rear casing aside for future use.
  2. Samsung Galaxy SIII Mini VE Battery Replacement, Removing the Battery: 步骤 2 中的图像 1,2 Samsung Galaxy SIII Mini VE Battery Replacement, Removing the Battery: 步骤 2 中的图像 2,2
    • The battery is the large grey and black rectangle.
    • Using your fingernail, or opening tool, gently pry the bottom of the battery until it pops out.
    • Place the old battery aside for now, or dispose of it properly.
  3. Samsung Galaxy SIII Mini VE Battery Replacement, Inserting New Battery: 步骤 3 中的图像 1,2 Samsung Galaxy SIII Mini VE Battery Replacement, Inserting New Battery: 步骤 3 中的图像 2,2
    • Locate your new battery.
    • Correctly orient the new battery to be inserted.
    • To orient the battery, make sure the 3 metallic bars align with the 3 prongs on the phone.
    • Gently insert the new battery into the battery slot.
结论
9等其他人完成本指南。
Megan
于10/23/14注册
1,186 声望
创作了6篇指南
团队
Michigan Tech, Team 1-8, Lauer Fall 2014 Michigan Tech, Team 1-8, Lauer Fall 2014 的会员
MTU-LAUER-F14S1G8
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 3,358
