跳转到主内容
Samsung Galaxy SIII Mini Display Assembly Replacement
你所需要的
视频概述
  1. Samsung Galaxy SIII Mini Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 1,2 Samsung Galaxy SIII Mini Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 2,2
    • LCD Display + Touch screen (Display Assemblay) for Samsung Galaxy S III mini / i8190.
    • Switch off the phone, remove the battery and any SIM and memory card.
  2. Samsung Galaxy SIII Mini Display Assembly Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy SIII Mini Display Assembly Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy SIII Mini Display Assembly Replacement: 步骤 2 中的图像 3,3
    • Remove 10x Phillips screws.
    • With a plastic tool remove the Middle frame.
  3. Samsung Galaxy SIII Mini Display Assembly Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy SIII Mini Display Assembly Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy SIII Mini Display Assembly Replacement: 步骤 3 中的图像 3,3
    • Disconnect:
    • Menu buttons flex cable
    • Micro SD Card reader flex cable
    • Lift up slightly the mother board from the right edge.
    • Unstick the Earpiece and Main camera from the display frame. Be careful, don't break flex cables.
    • Now disconnect the LCD Display flex cable which is located on the underside of the board.
  4. Samsung Galaxy SIII Mini Display Assembly Replacement: 步骤 4 中的图像 1,1
    • Front camera
    • Main / Rear camera
    • Earpiece
    • Loudspeaker
    • Vibro motor
  5. Samsung Galaxy SIII Mini Display Assembly Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy SIII Mini Display Assembly Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy SIII Mini Display Assembly Replacement: 步骤 5 中的图像 3,3
    • Let's test the new spare part.
    • First connect the Display assembly, grab the phone comfortably and then put the battery.
  6. Samsung Galaxy SIII Mini Display Assembly Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy SIII Mini Display Assembly Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy SIII Mini Display Assembly Replacement: 步骤 6 中的图像 3,3
    • Warm the touchscreen to make adhesive tape soft. You can use a hair dryer.
    • If the glass is cracked, put the tape in order not to scatter pieces.
    • Use the front camera hole to separate the glass at the corner.
    • Continue with separation with plastic tools, from up to down.
  7. Samsung Galaxy SIII Mini Display Assembly Replacement: 步骤 7 中的图像 1,3 Samsung Galaxy SIII Mini Display Assembly Replacement: 步骤 7 中的图像 2,3 Samsung Galaxy SIII Mini Display Assembly Replacement: 步骤 7 中的图像 3,3
    • Gently separate the menu buttons flex cable from the touchscreen.
  8. Samsung Galaxy SIII Mini Display Assembly Replacement: 步骤 8 中的图像 1,3 Samsung Galaxy SIII Mini Display Assembly Replacement: 步骤 8 中的图像 2,3 Samsung Galaxy SIII Mini Display Assembly Replacement: 步骤 8 中的图像 3,3
    • If the display is left on the frame, use the same techniques to remove it.
  9. Samsung Galaxy SIII Mini Display Assembly Replacement: 步骤 9 中的图像 1,3 Samsung Galaxy SIII Mini Display Assembly Replacement: 步骤 9 中的图像 2,3 Samsung Galaxy SIII Mini Display Assembly Replacement: 步骤 9 中的图像 3,3
    • Clean the frame from the remnants of tape and install new.
    • Be careful with the menu buttons and the holes for the camera and the light sensor, don't cover them.
  10. Samsung Galaxy SIII Mini Display Assembly Replacement: 步骤 10 中的图像 1,3 Samsung Galaxy SIII Mini Display Assembly Replacement: 步骤 10 中的图像 2,3 Samsung Galaxy SIII Mini Display Assembly Replacement: 步骤 10 中的图像 3,3
    • Will be easier if you use adhesive, ready for the model.
    • Install the new display assembly and start with reassembling.
  11. Samsung Galaxy SIII Mini Display Assembly Replacement: 步骤 11 中的图像 1,1
    • That's all.
    • Did you do it successfully?
结论
18等其他人完成本指南。
ZFix
于12/09/13注册
191,278 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,528篇指南
2条评论
Followed the VDO exactly and managed to fix the screen. Getting the right glue for the screen delivered took the longest time.
Erick Ogam - 回复
Worked perfectly, used regular glue I had at home and it worked just fine. Thanks!!
Elisa Díaz Ipes - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 17,497
