跳转到主内容
Samsung Galaxy SIII Mini Camera Failed Troubleshooting
你所需要的
视频概述
  1. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Camera Data and Cache: 步骤 1 中的图像 1,3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Camera Data and Cache: 步骤 1 中的图像 2,3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Camera Data and Cache: 步骤 1 中的图像 3,3
    • Go to:
    • > Settings
    • > Application manager
    • > All
    • >Camera
    • Clear data and cache and check that the camera works. If no, go to the next step.
  2. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Factory / Hard Reset: 步骤 2 中的图像 1,3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Factory / Hard Reset: 步骤 2 中的图像 2,3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Factory / Hard Reset: 步骤 2 中的图像 3,3
    • Go to:
    • > Settings > Backup and reset
    • > Factory data reset
    • > Reset device > Erase everithing
    • !!! This will erase all your data !!!
    • For a Hard reset using hardware keys, follow this manual:
    • Samsung Galaxy - Wipe data/Factory reset
  3. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Firmware: 步骤 3 中的图像 1,3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Firmware: 步骤 3 中的图像 2,3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Firmware: 步骤 3 中的图像 3,3
    • Open sammobile and make an registration.
    • Search the firmware for your model and find the variant, corresponding to your mobile phone.
    • You can see the variant from Settings > About the device, or from dialer app by entering *#1234#
    • In the download page you can find instructions and link to the Odin app.
  4. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Reconnecting Camera: 步骤 4 中的图像 1,3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Reconnecting Camera: 步骤 4 中的图像 2,3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Reconnecting Camera: 步骤 4 中的图像 3,3
    • Switch off the phone and remove the battery and any SIM and memory card.
    • Remove the Midframe.
    • Disconnect the Menu buttons and the SD card reader flex cables.
    • Lift the board slightly to the left side and be careful with the earpiece and the main camera - they are stuck to the Display frame.
  5. Samsung Galaxy SIII Mini Camera Failed Troubleshooting: 步骤 5 中的图像 1,3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting: 步骤 5 中的图像 2,3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting: 步骤 5 中的图像 3,3
    • Disconnect the LCD Display flex cable.
    • Open the camera flex cable connector and reconnect the camera.
  6. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Camera Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Camera Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Camera Replacement: 步骤 6 中的图像 3,3
    • If the camera still does not work, the last step is camera replacement.
  7. Samsung Galaxy SIII Mini Camera Failed Troubleshooting: 步骤 7 中的图像 1,1
    • Did you do it successfully?
结论
16等其他人完成本指南。
ZFix
于12/09/13注册
191,182 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,519篇指南
3条评论
I did it! I did it! I did it!
I save time and money!
Thank you sooooo much!
Batis Kaf - 回复
how did you do it?!
zohny.omar -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 9,546
