简介
This guide will explain how to replace the volume buttons cable on your Samsung Galaxy S8. This phone requires multiple screws to be removed, cables to be disconnected, and parts to be moved before you can access the volume button cable.
你所需要的
Heat an iOpener and apply it to a long edge of the S8 for about 2 minutes.
In the following steps you will be cutting through the adhesive around the edge of the rear glass panel.
The adhesive on the rear case is laid out as seen in the first image.
The prying pattern as seen from the outside of the phone is as follows:
Thick portions of adhesive
Thin areas of adhesive
Avoid prying here, to protect the fingerprint sensor.
在这个步骤中使用的工具:Tweezers$4.99
Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive.
Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
Detach the fingerprint scanner cable from the motherboard with the spudger.
另外一个人完成了本指南。
一条评论
Nice description. I would add in step 16 the following (since it is the most difficult part that needs attention):
* The volume up/down and Bixby button comprises two pieces, the one with contacts that are connected with the cable that is attached to the phone (part 1), and another part (part 2) that sits between the contacts (part 1) and the buttons you push outside from the phone (part 3).
* To pry the two pieces from the phone you should start to lift up the metal nose above the cable, which is connecting the buttons with the phone on the top close to the volume-up button.
* As soon it is coming out a little bit you can continue on the very top to lift up the power button as there is a little gap where you can squeeze the spudger in between the plastic cover and metal of the power button.
* Try to lift up the power button on the lower side close to the Bixby button next and continue on the top and button alternately.
* Take care since the two pieces are squeezed tightly into the cavity.
