简介
使用本指南来更换您的三星盖乐世 S8上破损或者坏掉的显示屏。
“注意”:这个指南只能运用于更换显示屏,同时保留原来的外框、主板和电池(而非更换)。但是该手机的一些替换屏幕预先安装在一个新的外框(A.K.AutoStudio)中,你需要一些不一样的工序来处理手机内部和安装一个新的电池。在执行这个指南之前一定要确保你有正确的组件。
本指南包括移除玻璃后壳,您将需要更换后壳上的粘合剂。 如果您更换的屏幕没有附带粘合剂,那您将需要使用胶带将它们粘起来。
“如果外框损坏或弯曲”,请一定要更换它,否则新的屏幕可能无法正确安装,并可能会因为不均匀压力的而损坏。
将显示屏与外框分离的过程通常会破坏显示屏,因此,除非您打算更换显示屏,否则不要执行此指南。
你所需要的
视频概述
在锅或平底锅里装满足够的水来完全淹没iOpener。
把水加热到沸腾。关火。
将iOpener放入热水中2-3分钟。确保iOpener完全浸入水中。
用钳子从热水中提取加热的iOpener。
用毛巾彻底擦干iOpener。
你的iOpener已准备好使用!如果你需要重新加热iOpener,请将水加热到沸点,关火,并将iOpener放入水中2-3分钟。
要重新组装您的设备,请按照本指南的相反顺序进行操作。
233等其他人完成本指南。
由衷感谢以下译者:
92%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
36条评论
Did my first repair two days ago. If you've done any other samsung repairs such as S7 or S7E, this will be cake for you to do. If you have big fingers like I do, the most challenging thing will be the fingerprint scanner flex on the back glass, connecting and reconnecting.
I go about this repair a bit differently if I want to salvage the lcd. I remove the battery motherboard and sensors , and start through the opening in the frame under the battery. I drip isopropyl alcohol along the perimeter of the battery opening applying heat and work a playing card in between the LCD and the frame, loosening adhesive as I go.
I like the way you think.
Thank you. My utterly novice self ordered only the glass, thinking it would be moderately easy for a layman. I didn't realize the LCD was nearly permanently stuck to it, and don't have $190 to replace it. I'll try your way. Thanks!
Great guide, very accurate. Be very careful along the right side of the device, as it is very, very easy to shear the connector flex in half. To avoid any chance of damage, I remove the board and front camera/sensor flex. It's an easy job, and saves a massive headache if any parts are damaged. Overall quite a familiar phone to work on, if you've ever done any S6's and upwards.
