跳转到主内容
Samsung Galaxy S8 Plus Display Assembly (With Frame) Replacement
你所需要的
视频介绍
结论
33等其他人完成本指南。
Jeff Suovanen
于08/06/13注册
428,713 声望
创作了259篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,299篇指南
5条评论
something to note, not sure if the guy mentions in video (it’s german, I didn't actually watch it) :
If you try and test the new display before you reassembled the mid frame, you will get a temperature warning. reinstall all screws and mid frame then test, should be good.
also, this is the only method you should attempt this repair, as the official samsung screens will come like this, with frame. If not, its not original, don’t waste your time or money on sh!tty parts
Andrew - 回复
Agreed! I love my OEM Samsung Service Box Display
Ethan Bain - 回复
Best video I’ve seen of the S8 teardown. Agree with what Andrew said above, check the midframe to see all the extra small parts are there. To check everything works, you can turn on the phone with after connecting the display to the motherboard, and puting the internals back together (everything but gluing the front and back pieces). Be careful to put all the screws back in place- the motherboard needs a tight connection to components on the midframe (like the power button and audio speaker) to work. Good luck!
Michael M - 回复
Can I buy the screen replacement
Christian lares - 回复
How can i by samsung Galaxy 8+ screen?
Nguse Hayelom - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 21
过去 30 天: 110
总计 31,193
