简介
使用本指南来更换您的Samsung Galaxy S8 上的NFC天线和无线充电线圈。
本指南包括了移除玻璃后壳,您将需要更换粘合剂来重新粘和后壳。
在拆解手机前,请断开充电电源,并将手机电量将至25%以下。 如果电池被意外刺穿就会很容易着火或者爆炸,低电量可以降低此种风险。
要重新组装您的设备,请按照本指南的相反顺序进行操作。
7等其他人完成本指南。
特别感谢这些译者︰
85%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
5条评论
Can I leave off the charging coil? I don't use the wireless charging..
Hi Stacy, the assembly that includes the wireless charging coil also houses antennas related to NFC and other phone functions. Most things might still work if you left the coil out, but I definitely wouldn’t recommend removing it.
Hi adam thanks for the guide. It helped a lot. I have a question could you please guide me how to hotwire the charging coil pins. Because as i connect the coil it will cause the black lines in the screen and as i remove it the black lines are gone but the phone wont charge showing the low temperature. As removing the coil somehow disconnects the charging mechanism. Thanks in advance.
Hi , my phone battery was going bad and it was overheating and sometimes would turn off when i was using it. know it is saying that the temperature is too low and this is after i changed the battery would removing the NFC antenna and charging coil stop this from happening
where i get repair my Samsung s8 mobile , it showing temperature low , pls send me address
