跳转到主内容
Samsung Galaxy S7 Edge Rear Camera Lens Replacement
你所需要的
    • Follow this procedure if you are replacing only the glass lens over the rear-facing camera.
    • If you are replacing the entire bezel, skip this step and follow the instructions in the next step.
    • Follow this longer procedure to replace the bezel and camera lens, which are installed on the rear case.
    • If you follow this procedure, you will need new adhesive to reinstall the rear case. Follow this guide to reinstall the camera bezel adhesive as well as the rear cover adhesive.
终点
18等其他人完成本指南。
Evan Noronha
于02/05/15注册
224,291 声望
创作了168篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 37
总计 22,294
