跳转到主内容
修复你的物品
维修的权力
商店
简介
If your main camera glass is broken, you can either remove and replace the lens glass, or replace the whole lens assembly.
Removing the lens while the phone is still assembled may cause small pieces of glass to fall into the camera, but is a faster fix that requires less disassembly.
The lens assembly replacement is longer, and requires removing the back panel, but it is less likely to damage the camera itself. This procedure includes replacing the glass lens and the camera bezel, and will require replacement rear glass adhesive.
    • Follow this procedure if you are replacing only the glass lens over the rear-facing camera.
    • If you are replacing the entire bezel, skip this step and follow the instructions in the next step.
    • Follow this longer procedure to replace the bezel and camera lens, which are installed on the rear case.
    • If you follow this procedure, you will need new adhesive to reinstall the rear case. Follow this guide to reinstall the camera bezel adhesive as well as the rear cover adhesive.
终点
15等其他人完成本指南。
Evan Noronha
于2015年02月05日注册
202,123 信誉积分
创作了178篇指南
团队
iFixit iFixit 的会员
Community
135 名成员
创作了13,859篇指南
添加评论
浏览统计数据:
过去的24小时: 5
过去的7天: 28
过去的30天: 121
总计 19,537
