跳转到主内容
Samsung Galaxy S7 Active Screen Replacement
你所需要的
  1. Samsung Galaxy S7 Active Screen Replacement, Samsung Galaxy S7 Active Disassembly: 步骤 1 中的图像 1,1
    • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
    • Your phone is hot, please do not touch it with your bare hand.
  2. Samsung Galaxy S7 Active Screen Replacement: 步骤 2 中的图像 1,1
    • Wedge the metal spudger in between the screen and the frame to begin separating them.
    • It would be easier to separate the screen from the sealing adhesive on the frame if you with more than one metal spudger.
    • Your phone might no longer be watertight after you reassemble it.
  3. Samsung Galaxy S7 Active Screen Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy S7 Active Screen Replacement: 步骤 3 中的图像 2,2
    • Slide the metal spudger around the phone at least once.
    • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
  4. Samsung Galaxy S7 Active Screen Replacement: 步骤 4 中的图像 1,1
    • Lift the screen up with your hands.
    • Please wash your hands thoroughly with hot water and soap after you finish.
  5. Samsung Galaxy S7 Active Screen Replacement, Screen: 步骤 5 中的图像 1,3 Samsung Galaxy S7 Active Screen Replacement, Screen: 步骤 5 中的图像 2,3 Samsung Galaxy S7 Active Screen Replacement, Screen: 步骤 5 中的图像 3,3
    • Use the tweezers to disconnect the screen from the phone by detaching the connection.
  6. Samsung Galaxy S7 Active Screen Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy S7 Active Screen Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy S7 Active Screen Replacement: 步骤 6 中的图像 3,3
    • Clean the rest of the adhesive left on the phone by scraping it off with a metal tool.
    • Apply rubbing alcohol on the adhesive to make sure phone is free of any adhesive. Do this by applying some rubbing alcohol onto a napkin.
    • Lightly proceed to clean the phone with that napkin.
结论
3等其他人完成本指南。
Erick Vazquez
于04/18/18注册
180 声望
撰写一个指南
团队
Cal Poly, Team S18-G1, Livingston Spring 2018 Cal Poly, Team S18-G1, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S18G1
4 名成员
创作了15篇指南
3条评论
Do you know where i can find a replacement screen assembly, cant find one anywhere
Sam Ellis - 回复
I bought a digitizer with fog and polarizer and a new front glass, it came with the loca. What else do I need to make the complete LCD screen assembly?
Michael Shep - 回复
The instructions are excessively brief. The photos are insufficient to convey the details of this operation. Attempted and damaged my phone.
RAC - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 16
总计 9,049
