跳转到主内容
Samsung Galaxy S7 Active Disassembly
你所需要的
  1. Samsung Galaxy S7 Active Disassembly, Samsung Galaxy S7 Active Disassembly: 步骤 1 中的图像 1,1
    • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
    • Your phone is hot, please do not touch it with your bare hand.
  2. Samsung Galaxy S7 Active Disassembly: 步骤 2 中的图像 1,1
    • Wedge the metal spudger in between the screen and the frame to begin separating them.
    • It would be easier to separate the screen from the sealing adhesive on the frame if you with more than one metal spudger.
    • Your phone might no longer be watertight after you reassemble it.
  3. Samsung Galaxy S7 Active Disassembly: 步骤 3 中的图像 1,2 Samsung Galaxy S7 Active Disassembly: 步骤 3 中的图像 2,2
    • Slide the metal spudger around the phone at least once.
    • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
  4. Samsung Galaxy S7 Active Disassembly: 步骤 4 中的图像 1,1
    • Lift the screen up with your hands.
    • Please wash your hands thoroughly with hot water and soap after you finish.
结论
3等其他人完成本指南。
团队
Cal Poly, Team S18-G1, Livingston Spring 2018 Cal Poly, Team S18-G1, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S18G1
4 名成员
创作了15篇指南
一条评论
What about fixing the phone sure you can take it apart but what about fixing
Robert Ydstie - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 22
总计 4,340
