跳转到主内容
Samsung Galaxy S7 Active Battery Replacement
你所需要的
  1. Samsung Galaxy S7 Active Battery Replacement, Samsung Galaxy S7 Active Disassembly: 步骤 1 中的图像 1,1
    • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
    • Your phone is hot, please do not touch it with your bare hand.
  2. Samsung Galaxy S7 Active Battery Replacement: 步骤 2 中的图像 1,1
    • Wedge the metal spudger in between the screen and the frame to begin separating them.
    • It would be easier to separate the screen from the sealing adhesive on the frame if you with more than one metal spudger.
    • Your phone might no longer be watertight after you reassemble it.
  3. Samsung Galaxy S7 Active Battery Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy S7 Active Battery Replacement: 步骤 3 中的图像 2,2
    • Slide the metal spudger around the phone at least once.
    • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
  4. Samsung Galaxy S7 Active Battery Replacement: 步骤 4 中的图像 1,1
    • Lift the screen up with your hands.
    • Please wash your hands thoroughly with hot water and soap after you finish.
  5. Samsung Galaxy S7 Active Battery Replacement, Battery: 步骤 5 中的图像 1,1
    • Use a Phillips #000 screwdriver to remove a single screw.
  6. Samsung Galaxy S7 Active Battery Replacement: 步骤 6 中的图像 1,1
    • Use tweezers to remove the small plastic cover you just unscrewed.
  7. Samsung Galaxy S7 Active Battery Replacement: 步骤 7 中的图像 1,1
    • Use tweezers to remove the other small plastic cover.
  8. Samsung Galaxy S7 Active Battery Replacement: 步骤 8 中的图像 1,1
    • Use a Phillips head #000 to take out the eleven screws marked in the photo.
  9. Samsung Galaxy S7 Active Battery Replacement: 步骤 9 中的图像 1,1
    • Use tweezers to disconnect the marked pieces from the motherboard.
  10. Samsung Galaxy S7 Active Battery Replacement: 步骤 10 中的图像 1,1
    • Use tweezers to take out the middle button and its connection to the motherboard.
  11. Samsung Galaxy S7 Active Battery Replacement: 步骤 11 中的图像 1,3 Samsung Galaxy S7 Active Battery Replacement: 步骤 11 中的图像 2,3 Samsung Galaxy S7 Active Battery Replacement: 步骤 11 中的图像 3,3
    • Use a metal spudger to pull the mid frame and battery off of the motherboard.
  12. Samsung Galaxy S7 Active Battery Replacement: 步骤 12 中的图像 1,2 Samsung Galaxy S7 Active Battery Replacement: 步骤 12 中的图像 2,2
    • Use a spudger to remove the battery from the midframe.
    • To install a new battery and adhesive, follow this guide.
结论
11等其他人完成本指南。
团队
Cal Poly, Team S18-G1, Livingston Spring 2018 Cal Poly, Team S18-G1, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S18G1
4 名成员
创作了15篇指南
3条评论
I would advise against using a metal spudger to remove the battery itself. While working at a device repair chain in the past, a coworker of mine punctured a battery with a metal spudger and destroyed the phone. Instead, use a sturdy plastic spudger to remove the battery. Otherwise, great guide!
Derek Margheim - 回复
I got the battery fixed but shattered my screen wish it was more informative on how to get out the screen
joshua hofer - 回复
Would using the Anti-clamp with heat gun be better option?
Kiriakos White - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 79
总计 24,462
