简介
根据本指南以更换三星盖乐世S6的Home键
本指南涉及到拆卸后部玻璃面板。拆卸后部玻璃面板需要去除将其固定到位的粘合剂。参考 本指南以重新安装后部玻璃面板。
你所需要的
在锅或平底锅里装满足够的水来完全淹没iOpener。
把水加热到沸腾。关火。
将iOpener放入热水中2-3分钟。确保iOpener完全浸入水中。
用钳子从热水中提取加热的iOpener。
用毛巾彻底擦干iOpener。
你的iOpener已准备好使用!如果你需要重新加热iOpener,请将水加热到沸点,关火,并将iOpener放入水中2-3分钟。
将iOpener放置在手机后盖上2分钟左右,以软化后盖的上的胶水。
你可能需要使用 iOpener 多次以达到足够的温度。 请按照 iOpener 的说明操作以避免过度加热。
移动iOpener以加热后壳的剩余部分,同样大约需要两分钟
参照以下介绍的相反步骤重新安装你的设备。若要重新组装后部玻璃面板,参考重新安装后部玻璃面板粘合剂指南。
23等其他人完成本指南。
由衷感谢以下译者:
90%
Z.Heng正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
6条评论
So it's literally the last thing you remove on the entire stinking thing /facepalm
You forgot to mention how to enable the fingerprint sensor when you replace the home button. When you replace the home button the fingerprint sensor wont work. Not sure what Samsung does but it has to be a software flash to allow the new part to marry to the mother board. There are lots of how to articles and videos that are half assed and just give enough info to get you into trouble. Though I wouldnt pay Samsung $100 to replace a button, these facts should be included in the repair article. Im really surprised no one has the fix for this in the form of an APK. Ive seen lots of screen replacement videos and all are half assed that show you the wrong way to remove the screen digitizer. I ripped my home button and back buttons circuit because of idiots that post how to videos that skip these important steps. I wish I would have paid the extra $$ and had the local shop do my repair from the start. He told me that the sensor wont work after repair and so far he is correct.
I broke my display doing this :( I suggest you not to do it if you are not 100 % sure of yours skills.
