跳转到主内容
Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement
你所需要的
  1. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement, Rear Glass Adhesive: 步骤 1 中的图像 1,3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement, Rear Glass Adhesive: 步骤 1 中的图像 2,3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement, Rear Glass Adhesive: 步骤 1 中的图像 3,3
    • Peel the clear film off of the adhesive packaging.
  2. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 步骤 2 中的图像 3,3
    • Lay the glass panel face-up and rotate it so that the lens holes are on your right.
    • Grasp the adhesive from both sides and align the tape over the rear glass.
    • Make sure to align the camera and heart rate sensor holes on the phone with the adhesive tape.
    • Lay the adhesive on top of the glass.
  3. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 步骤 3 中的图像 3,3
    • Run your fingers over the tape to firmly attach it to the glass.
  4. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 步骤 4 中的图像 3,3
    • Peel back the outer layer of green film.
  5. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 步骤 5 中的图像 3,3
    • Peel back the inner film layer.
  6. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 步骤 6 中的图像 3,3
    • If you didn't perfectly align the adhesive with the panel, use an X-Acto knife to trim away the edges.
    • This will only fix minor misalignments. If you have to trim off more than half the adhesive strip, you should remove the tape and start over.
  7. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 步骤 7 中的图像 1,2 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers to remove any adhesive still on the midframe.
    • Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth.
  8. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 步骤 8 中的图像 1,3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 步骤 8 中的图像 2,3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 步骤 8 中的图像 3,3
    • Align the top of the rear glass with the top of the phone.
    • Press the top edge of the glass into the midframe so that there's no gap at the top.
  9. Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 步骤 9 中的图像 1,3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 步骤 9 中的图像 2,3 Samsung Galaxy S6 Edge Rear Glass Adhesive Replacement: 步骤 9 中的图像 3,3
    • Lower the rest of the rear panel and press it firmly into the midframe.
终点
81等其他人完成本指南。
Sam Goldheart
于10/18/12注册
465,970 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,299篇指南
3条评论
Where do you by the adhesive strip for the repair
Nico Velasquez - 回复
There are a lot of places like replacebase
Allspares,and a lot other but usually the back glass comes with the adhesive on
Alkinos vasiliou -
How strong is the s6 edge plus rear glass are they known to break easy.
Aaron c - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 70
总计 34,005
