你所需要的
视频概述
Remove the back cover at first. It's a pity that we only have a S6 with broken back cover to show how to do camera lens glass replacement.
在这个步骤中使用的工具:Tweezers$4.99
And then pry up the camera lens ring from bottom right corner. There is some adhesive underneath. Be careful and avoid scratching the metal ring with sharp tweezers.
At last, push the camera lens glass by your finger or with a spudger and remove it finally.
54等其他人完成本指南。
27条评论
Is it possible to replace just the lens without taking off the back cover? Like can I just use a suction tool to pull off the broken lens and put in the new one?
Yes, that is possible!
Robin -
Yes. It can be done. I did it using a hair dryer to warm the lens and peel if off gently, starting in one corner. If it seems reluctant to come off you may need to heat it a little more. Be careful not to damage to outer metal ring (as I did) and then replace the glass lens as described.
