跳转到主内容
简介
Over-charging, water damage, or quickly and repeatedly inserting and removing a USB device may lead to a damage on the USB board of the Samsung Galaxy S6 Active. Use this guide to replace the USB board in your Samsung Galaxy S6 Active.
Before beginning, make sure to completely power off your phone and disconnect it from any external power source.
  1. Samsung Galaxy S6 Active USB Board Replacement, SIM Card: 步骤 1 中的图像 1,2 Samsung Galaxy S6 Active USB Board Replacement, SIM Card: 步骤 1 中的图像 2,2
    • Insert your fingernail or a plastic opening tool into the pivot on the side of the SIM tray.
    • Pry open the tray to get it out of the socket.
  2. Samsung Galaxy S6 Active USB Board Replacement: 步骤 2 中的图像 1,1
    • Remove the SIM tray with SIM card from the phone.
  3. Samsung Galaxy S6 Active USB Board Replacement, Display Assembly: 步骤 3 中的图像 1,3 Samsung Galaxy S6 Active USB Board Replacement, Display Assembly: 步骤 3 中的图像 2,3 Samsung Galaxy S6 Active USB Board Replacement, Display Assembly: 步骤 3 中的图像 3,3
    • Heat the front face (sides, top, bottom) of the phone with the iOpener, a hair dryer, or a heat gun for 60 seconds to loosen the adhesive around the edge of the glass.
    • If using an iOpener, heat it in a microwave for thirty seconds.
  4. Samsung Galaxy S6 Active USB Board Replacement: 步骤 4 中的图像 1,1
    • Attach a suction cup to the lower half of the screen.
  5. Samsung Galaxy S6 Active USB Board Replacement: 步骤 5 中的图像 1,2 Samsung Galaxy S6 Active USB Board Replacement: 步骤 5 中的图像 2,2
    • Using the suction cup, pull gently the lower half of the panel.
    • If you pull too hard you may break the display. If you still feel resistance repeat Step 3, leaving the iOpener on longer.
  6. Samsung Galaxy S6 Active USB Board Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy S6 Active USB Board Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy S6 Active USB Board Replacement: 步骤 6 中的图像 3,3
    • Once you’ve opened a large enough gap, insert a plastic tool at the bottom, between the glass and the rest of frame of the phone.
    • Slide the plastic opening tool around the screen, prying the display gently away from the body
  7. Samsung Galaxy S6 Active USB Board Replacement: 步骤 7 中的图像 1,1
    • Pull the lower half of the screen screen with the suction cup while holding down the frame of the phone to separate both components.
    • Only lift the lower part of the screen. It is connected with a clip to the top of the motherboard and can rip off if you pull too hard.
  8. Samsung Galaxy S6 Active USB Board Replacement: 步骤 8 中的图像 1,3 Samsung Galaxy S6 Active USB Board Replacement: 步骤 8 中的图像 2,3 Samsung Galaxy S6 Active USB Board Replacement: 步骤 8 中的图像 3,3
    • Once the glass is off, you will see a small clip covering the screen connection to the motherboard at the top of the phone. Use tweezers to grab the clip by the crease on its side and pull it out.
  9. Samsung Galaxy S6 Active USB Board Replacement: 步骤 9 中的图像 1,1
    • Undo the screen connection with a plastic tool.
  10. Samsung Galaxy S6 Active USB Board Replacement: 步骤 10 中的图像 1,1
    • Remove the display assembly (LCD and Digitizer).
  11. Samsung Galaxy S6 Active USB Board Replacement, Battery: 步骤 11 中的图像 1,2 Samsung Galaxy S6 Active USB Board Replacement, Battery: 步骤 11 中的图像 2,2
    • Use the Phillips Head Screwdriver sized PH000 to remove the sixteen 4mm screws from the frame.
  12. Samsung Galaxy S6 Active USB Board Replacement: 步骤 12 中的图像 1,1
    • Put a little pressure on the top, on the bottom, and on the sides of the phone to separate the rear case.
    • You will hear the clips start undoing themselves.
  13. Samsung Galaxy S6 Active USB Board Replacement: 步骤 13 中的图像 1,2 Samsung Galaxy S6 Active USB Board Replacement: 步骤 13 中的图像 2,2
    • Once all the clips have popped, pull out the rear case to separate it from the frame with the battery.
    • The battery will be on the back side of this frame.
  14. Samsung Galaxy S6 Active USB Board Replacement: 步骤 14 中的图像 1,1
    • Insert a plastic opening tool on the side of the frame and pull out the battery.
  15. Samsung Galaxy S6 Active USB Board Replacement: 步骤 15 中的图像 1,2 Samsung Galaxy S6 Active USB Board Replacement: 步骤 15 中的图像 2,2
    • Remove the battery from the frame.
  16. Samsung Galaxy S6 Active USB Board Replacement, USB Board: 步骤 16 中的图像 1,2 Samsung Galaxy S6 Active USB Board Replacement, USB Board: 步骤 16 中的图像 2,2
    • Use a plastic opening tool to undo the connector and the two wires on the motherboard.
  17. Samsung Galaxy S6 Active USB Board Replacement: 步骤 17 中的图像 1,1
    • Use the Phillips #000 screwdriver to remove the two 4mm screws from the USB board.
  18. Samsung Galaxy S6 Active USB Board Replacement: 步骤 18 中的图像 1,1
    • Insert a plastic opening tool under the USB board and remove the USB board from the rear case.
结论
Henry Salinas
于2019年11月07日注册
181 声望分
创作了2篇指南
团队
IUPUI, Team S2-G6, Harley Fall 2019 IUPUI, Team S2-G6, Harley Fall 2019 的会员
IUPUI-HARLEY-F19S2G6
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 9
总计 400
