简介
If your Samsung Galaxy S6 Active isn’t producing clear audio through headphones or auxiliary speakers, use this guide to replace the headphone jack.
Before using this guide, inspect the headphone jack for any debris that may be affecting the sound quality of the phone. Typically, a small buildup dust can be cause of the headphone jack not functioning properly. Be sure to use an ESD-safe brush or a small dust blower to remove this buildup of dust. Test a few sets of headphones or auxiliary cords with your phone to confirm that the faulty part is coming from the Samsung Galaxy S6 Active’s headphone jack.
Before beginning, make sure to completely power off your phone and disconnect it from any external power source.
你所需要的
Insert your fingernail or a plastic opening tool into the pivot on the side of the SIM tray.
Pry open the tray to get it out of the socket.
Heat the front face (sides, top, bottom) of the phone with the iOpener, a hair dryer, or a heat gun for 60 seconds to loosen the adhesive around the edge of the glass.
Use the Phillips Head Screwdriver sized PH000 to remove the sixteen 4mm screws from the frame.
Insert a spudger at the bottom, between the headphone jack connection and the rear case, to loosen the headphone jack.
