跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Samsung Galaxy S6 Active Front Camera Replacement
你所需要的
  1. Samsung Galaxy S6 Active Front Camera Replacement, SIM Card: 步骤 1 中的图像 1,2 Samsung Galaxy S6 Active Front Camera Replacement, SIM Card: 步骤 1 中的图像 2,2
    • Insert your fingernail or a plastic opening tool into the pivot on the side of the SIM tray.
    • Pry open the tray to get it out of the socket.
  2. Samsung Galaxy S6 Active Front Camera Replacement: 步骤 2 中的图像 1,1
    • Remove the SIM tray with SIM card from the phone.
  3. Samsung Galaxy S6 Active Front Camera Replacement, Display Assembly: 步骤 3 中的图像 1,3 Samsung Galaxy S6 Active Front Camera Replacement, Display Assembly: 步骤 3 中的图像 2,3 Samsung Galaxy S6 Active Front Camera Replacement, Display Assembly: 步骤 3 中的图像 3,3
    • Heat the front face (sides, top, bottom) of the phone with the iOpener, a hair dryer, or a heat gun for 60 seconds to loosen the adhesive around the edge of the glass.
    • If using an iOpener, heat it in a microwave for thirty seconds.
  4. Samsung Galaxy S6 Active Front Camera Replacement: 步骤 4 中的图像 1,1
    • Attach a suction cup to the lower half of the screen.
  5. Samsung Galaxy S6 Active Front Camera Replacement: 步骤 5 中的图像 1,2 Samsung Galaxy S6 Active Front Camera Replacement: 步骤 5 中的图像 2,2
    • Using the suction cup, pull gently the lower half of the panel.
    • If you pull too hard you may break the display. If you still feel resistance repeat Step 3, leaving the iOpener on longer.
  6. Samsung Galaxy S6 Active Front Camera Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy S6 Active Front Camera Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy S6 Active Front Camera Replacement: 步骤 6 中的图像 3,3
    • Once you’ve opened a large enough gap, insert a plastic tool at the bottom, between the glass and the rest of frame of the phone.
    • Slide the plastic opening tool around the screen, prying the display gently away from the body
  7. Samsung Galaxy S6 Active Front Camera Replacement: 步骤 7 中的图像 1,1
    • Pull the lower half of the screen screen with the suction cup while holding down the frame of the phone to separate both components.
    • Only lift the lower part of the screen. It is connected with a clip to the top of the motherboard and can rip off if you pull too hard.
  8. Samsung Galaxy S6 Active Front Camera Replacement: 步骤 8 中的图像 1,3 Samsung Galaxy S6 Active Front Camera Replacement: 步骤 8 中的图像 2,3 Samsung Galaxy S6 Active Front Camera Replacement: 步骤 8 中的图像 3,3
    • Once the glass is off, you will see a small clip covering the screen connection to the motherboard at the top of the phone. Use tweezers to grab the clip by the crease on its side and pull it out.
  9. Samsung Galaxy S6 Active Front Camera Replacement: 步骤 9 中的图像 1,1
    • Undo the screen connection with a plastic tool.
  10. Samsung Galaxy S6 Active Front Camera Replacement: 步骤 10 中的图像 1,1
    • Remove the display assembly (LCD and Digitizer).
  11. Samsung Galaxy S6 Active Front Camera Replacement, Battery: 步骤 11 中的图像 1,2 Samsung Galaxy S6 Active Front Camera Replacement, Battery: 步骤 11 中的图像 2,2
    • Use the Phillips Head Screwdriver sized PH000 to remove the sixteen 4mm screws from the frame.
  12. Samsung Galaxy S6 Active Front Camera Replacement: 步骤 12 中的图像 1,1
    • Put a little pressure on the top, on the bottom, and on the sides of the phone to separate the rear case.
    • You will hear the clips start undoing themselves.
  13. Samsung Galaxy S6 Active Front Camera Replacement: 步骤 13 中的图像 1,2 Samsung Galaxy S6 Active Front Camera Replacement: 步骤 13 中的图像 2,2
    • Once all the clips have popped, pull out the rear case to separate it from the frame with the battery.
    • The battery will be on the back side of this frame.
  14. Samsung Galaxy S6 Active Front Camera Replacement: 步骤 14 中的图像 1,1
    • Insert a plastic opening tool on the side of the frame and pull out the battery.
  15. Samsung Galaxy S6 Active Front Camera Replacement: 步骤 15 中的图像 1,2 Samsung Galaxy S6 Active Front Camera Replacement: 步骤 15 中的图像 2,2
    • Remove the battery from the frame.
  16. Samsung Galaxy S6 Active Front Camera Replacement, Motherboard: 步骤 16 中的图像 1,3 Samsung Galaxy S6 Active Front Camera Replacement, Motherboard: 步骤 16 中的图像 2,3 Samsung Galaxy S6 Active Front Camera Replacement, Motherboard: 步骤 16 中的图像 3,3
    • Use a plastic tool to undo all the connections in the motherboard.
    • There are three connections that have to be removed.
  17. Samsung Galaxy S6 Active Front Camera Replacement: 步骤 17 中的图像 1,2 Samsung Galaxy S6 Active Front Camera Replacement: 步骤 17 中的图像 2,2
    • Insert the flats end of the spudger below the motherboard and twist it to pry the board up.
  18. Samsung Galaxy S6 Active Front Camera Replacement: 步骤 18 中的图像 1,1
    • Remove the motherboard from the rear case.
  19. Samsung Galaxy S6 Active Front Camera Replacement, Front Camera: 步骤 19 中的图像 1,2 Samsung Galaxy S6 Active Front Camera Replacement, Front Camera: 步骤 19 中的图像 2,2
    • The front camera will be attached to the back of the motherboard.
    • Turn the motherboard around and use a plastic tool to undo the connection of the front camera.
  20. Samsung Galaxy S6 Active Front Camera Replacement: 步骤 20 中的图像 1,1
    • Use the tweezers to remove the front camera from the motherboard.
结论
另外一个人完成了本指南。
Lucia Valbuena
于02/15/17注册
2,412 声望
创作了8篇指南
团队
USF Tampa, Team 1-5, Sullivan Spring 2017 USF Tampa, Team 1-5, Sullivan Spring 2017 的会员
USFT-SULLIVAN-S17S1G5
3 名成员
创作了25篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 592
