跳转到主内容
Samsung Galaxy S5 Sport Screen Replacement
你所需要的
  1. Samsung Galaxy S5 Sport Screen Replacement, Battery: 步骤 1 中的图像 1,3 Samsung Galaxy S5 Sport Screen Replacement, Battery: 步骤 1 中的图像 2,3 Samsung Galaxy S5 Sport Screen Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove the back casing of the phone using the notch located at the top.
  2. Samsung Galaxy S5 Sport Screen Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy S5 Sport Screen Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy S5 Sport Screen Replacement: 步骤 2 中的图像 3,3
    • Lift up the battery using a plastic spudger or fingernail.
    • Damaging the battery may result in physical injury and/or damage to the phone.
  3. Samsung Galaxy S5 Sport Screen Replacement, Screen: 步骤 3 中的图像 1,3 Samsung Galaxy S5 Sport Screen Replacement, Screen: 步骤 3 中的图像 2,3 Samsung Galaxy S5 Sport Screen Replacement, Screen: 步骤 3 中的图像 3,3
    • Using a plastic opening tool or spudger, pry up the screen after the adhesive has melted.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Because it is a water-resistant phone, the screen cannot be taken apart without breaking.
  4. Samsung Galaxy S5 Sport Screen Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy S5 Sport Screen Replacement: 步骤 4 中的图像 2,2
    • The plastic cover of the phone may separate from the LCD screen. If so, also remove the LCD screen with the regular nylon spudger.
    • In the upper right area of the LCD screen, there is a connecting ribbon. Be careful not to rip its connection to the motherboard.
    • Do not hold the phone too close to your face or eyes. Small glass shards may dislodge or the metal spudger may slip.
结论
4等其他人完成本指南。
团队
USF Tampa, Team 1-6, Leahy Spring 2016 USF Tampa, Team 1-6, Leahy Spring 2016 的会员
USFT-LEAHY-S16S1G6
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 3,886
