跳转到主内容
Samsung Galaxy S5 Sport Rear Camera Replacement
你所需要的
  1. Samsung Galaxy S5 Sport Rear Camera Replacement, Battery: 步骤 1 中的图像 1,3 Samsung Galaxy S5 Sport Rear Camera Replacement, Battery: 步骤 1 中的图像 2,3 Samsung Galaxy S5 Sport Rear Camera Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove the back casing of the phone using the notch located at the top.
  2. Samsung Galaxy S5 Sport Rear Camera Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy S5 Sport Rear Camera Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy S5 Sport Rear Camera Replacement: 步骤 2 中的图像 3,3
    • Lift up the battery using a plastic spudger or fingernail.
    • Damaging the battery may result in physical injury and/or damage to the phone.
  3. Samsung Galaxy S5 Sport Rear Camera Replacement, Screen: 步骤 3 中的图像 1,3 Samsung Galaxy S5 Sport Rear Camera Replacement, Screen: 步骤 3 中的图像 2,3 Samsung Galaxy S5 Sport Rear Camera Replacement, Screen: 步骤 3 中的图像 3,3
    • Using a plastic opening tool or spudger, pry up the screen after the adhesive has melted.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Because it is a water-resistant phone, the screen cannot be taken apart without breaking.
  4. Samsung Galaxy S5 Sport Rear Camera Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy S5 Sport Rear Camera Replacement: 步骤 4 中的图像 2,2
    • The plastic cover of the phone may separate from the LCD screen. If so, also remove the LCD screen with the regular nylon spudger.
    • In the upper right area of the LCD screen, there is a connecting ribbon. Be careful not to rip its connection to the motherboard.
    • Do not hold the phone too close to your face or eyes. Small glass shards may dislodge or the metal spudger may slip.
  5. Samsung Galaxy S5 Sport Rear Camera Replacement, Rear Camera: 步骤 5 中的图像 1,3 Samsung Galaxy S5 Sport Rear Camera Replacement, Rear Camera: 步骤 5 中的图像 2,3 Samsung Galaxy S5 Sport Rear Camera Replacement, Rear Camera: 步骤 5 中的图像 3,3
    • Remove the seventeen screws around the plate.
  6. Samsung Galaxy S5 Sport Rear Camera Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy S5 Sport Rear Camera Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy S5 Sport Rear Camera Replacement: 步骤 6 中的图像 3,3
    • Push the plate out by applying pressure to the battery cavity.
  7. Samsung Galaxy S5 Sport Rear Camera Replacement: 步骤 7 中的图像 1,2 Samsung Galaxy S5 Sport Rear Camera Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Remove the back facing camera from the top of the phone by first disconnecting the ribbon cable from the connector with a spudger or tweezers.
    • Apply delicate pressure.
结论
团队
USF Tampa, Team 1-6, Leahy Spring 2016 USF Tampa, Team 1-6, Leahy Spring 2016 的会员
USFT-LEAHY-S16S1G6
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 746
