跳转到主内容
Samsung Galaxy S5 Mini Battery Replacement
你所需要的
  1. Samsung Galaxy S5 Mini Battery Replacement, Rear Panel: 步骤 1 中的图像 1,3 Samsung Galaxy S5 Mini Battery Replacement, Rear Panel: 步骤 1 中的图像 2,3 Samsung Galaxy S5 Mini Battery Replacement, Rear Panel: 步骤 1 中的图像 3,3
    • Insert a fingernail or a plastic opening tool into the slot located above the power button.
    • Gently pull the panel off the back of the phone.
    • The plastic snaps will make a popping sound as they separate.
  2. Samsung Galaxy S5 Mini Battery Replacement, Battery: 步骤 2 中的图像 1,3 Samsung Galaxy S5 Mini Battery Replacement, Battery: 步骤 2 中的图像 2,3 Samsung Galaxy S5 Mini Battery Replacement, Battery: 步骤 2 中的图像 3,3
    • Insert fingernail or plastic opening tool into the slot at the bottom of the battery.
    • Gently pry the battery away from the phone.
    • When replacing the battery, ensure the contacts are aligned and press lightly. The battery will appear to fit in multiple directions, so do not force it in.
结论
7等其他人完成本指南。
Ethan Juhnke
于09/29/14注册
162 声望
撰写一个指南
团队
Cal Poly, Team 12-4, Forte Fall 2014 Cal Poly, Team 12-4, Forte Fall 2014 的会员
CPSU-FORTE-F14S12G4
5 名成员
创作了38篇指南
2条评论
that was so so hard!
dennysb de - 回复
But battery not charging properly
kapil jadhav - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 52
总计 10,274
