简介
The display removal or replacement is a procedure of moderate difficulty. It involves the use of a few tools such as a guitar pick, and a heat gun. You should be aware of the hazards and safety procedures of these tools before starting the process.
你所需要的
Insert your fingernail or plastic opening tool into the divot at the top of the rear-facing camera.
Gently pry and twist the flexible rear cover off the back of the phone.
Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
Remove the battery away from the phone.
Use a heat gun at an approximate distance of 2-3 inches from the phone to apply heat to the phone and loosen up the adhesive in the display.
54等其他人完成本指南。
11条评论
If your screen is already broken you don't have to use so much heat. Once a corner is up and broken simply peel the screen off. Be aware that it will make a mess, so try to do this in a plastic bag or something
mangerszve - 回复
How do I just repare a cracked screen. Not the LCD
It's a really difficult and risky repair unless you have specialized tools. You can use a hot plate to separate the lcd from the glass and work it apart with a playing card, then use a special uv adhesive to attach the new one . Most skilled technicians and repair shops won't attempt this repair because of how fragile the lcd is. They make machines that automatically separate the lcd from the glass but it's still a risky repair. I wouldn't recommend trying it unless you want to do it as a learning experience. You'll most likely have to replace the entire screen.
Zach -
My question is can I use the LCD screen from Samsung Galaxy s5 to Samsung Galaxy s5 active? , I mean took out the glass just using lcd only
