跳转到主内容
Samsung Galaxy S5 Active Battery Replacement
你所需要的
  1. Samsung Galaxy S5 Active Battery Replacement, Rear Case: 步骤 1 中的图像 1,3 Samsung Galaxy S5 Active Battery Replacement, Rear Case: 步骤 1 中的图像 2,3 Samsung Galaxy S5 Active Battery Replacement, Rear Case: 步骤 1 中的图像 3,3
    • Insert your fingernail or plastic opening tool into the divot at the top of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
  2. Samsung Galaxy S5 Active Battery Replacement, Battery: 步骤 2 中的图像 1,3 Samsung Galaxy S5 Active Battery Replacement, Battery: 步骤 2 中的图像 2,3 Samsung Galaxy S5 Active Battery Replacement, Battery: 步骤 2 中的图像 3,3
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery away from the phone.
结论
To install the new battery, follow these instructions in reverse order.
11等其他人完成本指南。
团队
USF Tampa, Team 1-5, Hickman Fall 2014 USF Tampa, Team 1-5, Hickman Fall 2014 的会员
USFT-HICKMAN-F14S1G5
3 名成员
创作了7篇指南
一条评论
Awesome! I called around to the “WeFixYourPhone” places and they told me that battery couldn’t be replaced in a Samsung S5 Active, or they’d replace it for $40 if I bought the battery. Battery $13.50 for a 3200 mAmp one, Amazon Primed it to me. And the 45 seconds to replace it is no joke. That’s all it took. It took longer to get the Otter Box off the phone.
Lisa Swager - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 23
总计 26,488
