简介
取代三星Galaxy S4主板的先决条件。
你所需要的
断开耳机插孔总成的排线接头。
断开显示器/数字化器排线连接器。
断开天线排线接头。
My model had an antenna connection next to the usb board connector in addition to the antenna connection near the display cable connector.
That's point a, on the daughter board (where the USB is located is point b. You must connect it from a to b
I could not get the screen connector to fit on with the motherboard assembly in place. I had to remove the motherboard assembly, attach the screen connector, and then carefully replace the motherboard assembly, with the screen connector still attached..
Same as Tom4G above. When trying to connect the screen connector, it would not give me that nice clear snap indicating a positive connection. The phone powered up with no screen. So, I disconnected the other connectors again, lifted the motherboard out and connected the screen connector by pinching it with finger and thumb from both sides of the motherboard, this time getting a nice snap when it engaged.
speedrzr -
将您的设备,遵循这些指示,逆向重组。
将您的设备,遵循这些指示,逆向重组。
12等其他人完成本指南。
由衷感谢以下译者:
100%
Leeroy_正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
