跳转到主内容
Samsung Galaxy S4 Mini Speaker Replacement
你所需要的
  1. Samsung Galaxy S4 Mini Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Press and hold the END key to power the phone down.
  2. Samsung Galaxy S4 Mini Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove the back cover of the cell phone using a plastic opening tool.
  3. Samsung Galaxy S4 Mini Speaker Replacement: 步骤 3 中的图像 1,1
    • Pry the battery out using a plastic opening tool.
  4. Samsung Galaxy S4 Mini Speaker Replacement, Sim Card and Memory Card: 步骤 4 中的图像 1,2 Samsung Galaxy S4 Mini Speaker Replacement, Sim Card and Memory Card: 步骤 4 中的图像 2,2
    • Remove Sim Card using a tweezer or fingers
    • Remove Memory Card using a tweezer or fingers
  5. Samsung Galaxy S4 Mini Speaker Replacement, Grey Cover: 步骤 5 中的图像 1,1
    • In the back, there are 10 screws with a , which have to be removed with a small Phillips screwdriver tool.
  6. Samsung Galaxy S4 Mini Speaker Replacement, Gray cover: 步骤 6 中的图像 1,3 Samsung Galaxy S4 Mini Speaker Replacement, Gray cover: 步骤 6 中的图像 2,3 Samsung Galaxy S4 Mini Speaker Replacement, Gray cover: 步骤 6 中的图像 3,3
    • Then, use the plastic opening tool around the cellphone to open the plastic gray cover
    • Exert the gray cover from the plate and screen would come out easily.
  7. Samsung Galaxy S4 Mini Speaker Replacement, Loud Speaker: 步骤 7 中的图像 1,2 Samsung Galaxy S4 Mini Speaker Replacement, Loud Speaker: 步骤 7 中的图像 2,2
    • Exert some pressure on the gray cover to separate the loud speaker from the plate.
  8. Samsung Galaxy S4 Mini Speaker Replacement, New Loud Speaker: 步骤 8 中的图像 1,1
    • Insert the new loud speaker
结论
31等其他人完成本指南。
Luis Ojeda
于09/23/14注册
989 声望
撰写一个指南
团队
USF Tampa, Team 9-2, Blackwell Fall 2014 USF Tampa, Team 9-2, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S9G2
5 名成员
创作了11篇指南
3条评论
my phone has sound!!!!!! thank you for the tech advice
Stevie Jackson - 回复
perfect. thankyou
rick bailey - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 13,793
