跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
If you're finding that you cannot install anything new or save any pictures it is most likely due to the fact that the memory card on the phone is full.
  1. Press and hold the END key to power the phone down.
    • Press and hold the END key to power the phone down.
  2. Remove the back cover of the cell phone using a plastic opening tool.
    • Remove the back cover of the cell phone using a plastic opening tool.
  3. 任天堂 Switch 套装
    A quick fix to get back in the game
    Shop Switch Kits
    任天堂 Switch 套装
    Shop Switch Kits
  4. Pry the battery out using a plastic opening tool.
    • Pry the battery out using a plastic opening tool.
  5. Using a nylon spudger, push through the hole at the top of the memory card holder to slide it out.
    • Using a nylon spudger, push through the hole at the top of the memory card holder to slide it out.
结论
3等其他人完成本指南。
Arletty
于2014年09月25日注册
1,037 信誉积分
创作了2篇指南
团队
USF Tampa, Team 9-2, Blackwell Fall 2014 USF Tampa, Team 9-2, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S9G2
5 名成员
创作了10篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 7
总计 4,101
