跳转到主内容
Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]
你所需要的
  1. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], Battery: 步骤 1 中的图像 1,1
    • Press and hold the END key to power the phone down.
  2. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 步骤 2 中的图像 1,1
    • Remove the back cover of the cell phone using a plastic opening tool.
  3. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 步骤 3 中的图像 1,1
    • Pry the battery out using a plastic opening tool.
  4. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SIM Card: 步骤 4 中的图像 1,2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SIM Card: 步骤 4 中的图像 2,2
    • Using tweezers, remove the SIM card by sliding it towards the bottom of the device.
  5. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SD Card: 步骤 5 中的图像 1,1
    • Using a nylon spudger, push through the hole at the top of the memory card holder to slide it out.
  6. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], Motherboard [Verizon]: 步骤 6 中的图像 1,1
    • Remove the ten 4.0 mm screws on the back of the phone using the #00 Phillips screwdriver.
  7. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 步骤 7 中的图像 1,2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 步骤 7 中的图像 2,2
    • Starting at the USB port, slide a plastic opening tool around the perimeter of the phone between the rear housing and frame. As you work your way around the edge, you will feel the clips release.
    • Carefully separate the rear housing and the mid-frame to reveal the inside of the phone.
  8. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 步骤 8 中的图像 1,1
    • Use a pair of tweezers to lift the two charging assembly press fit connectors free.
  9. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 步骤 9 中的图像 1,2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 步骤 9 中的图像 2,2
    • Use the flat end of a nylon spudger to lift the headphone jack press-fit connector up to release the ribbon cable.
    • This part might be different if your device is using duo SIM
  10. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 步骤 10 中的图像 1,2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 步骤 10 中的图像 2,2
    • Use the flat end of a nylon spudger to lift the infrared sensor press-fit connector up to release the ribbon cable.
  11. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 步骤 11 中的图像 1,2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 步骤 11 中的图像 2,2
    • Use the flat end of a nylon spudger to lift the front-facing camera press-fit connector up to release the ribbon cable.
  12. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 步骤 12 中的图像 1,3 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 步骤 12 中的图像 2,3 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 步骤 12 中的图像 3,3
    • Gently lift the motherboard up and partially away from the device.
    • The digitizer ribbon cable is still attached to the underside of the motherboard.
  13. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 步骤 13 中的图像 1,2 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: 步骤 13 中的图像 2,2
    • Put the flat end of a nylon spudger under the lip of the digitizer press-fit connector and lift up to release the connector and free the motherboard.
结论
3等其他人完成本指南。
Richard
于02/07/17注册
30,024 声望
创作了11篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
一条评论
Thank You so much!
Peter Handless - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 18
总计 5,178
