跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Use this guide to replace the charging assembly in the event of an inability to charge.
  1. Press and hold the END key to power the phone down.
    • Press and hold the END key to power the phone down.
  2. Remove the back cover of the cell phone using a plastic opening tool.
    • Remove the back cover of the cell phone using a plastic opening tool.
  3. Pry the battery out using a plastic opening tool.
    • Pry the battery out using a plastic opening tool.
  4. Using tweezers, remove the SIM card by sliding it towards the bottom of the device. Using tweezers, remove the SIM card by sliding it towards the bottom of the device.
    • Using tweezers, remove the SIM card by sliding it towards the bottom of the device.
  5. 任天堂 Switch 套装
    A quick fix to get back in the game
    Shop Switch Kits
    任天堂 Switch 套装
    Shop Switch Kits
  6. Using a nylon spudger, push through the hole at the top of the memory card holder to slide it out.
    • Using a nylon spudger, push through the hole at the top of the memory card holder to slide it out.
  7. Remove the 10 4.0 mm Phillips screws on the back of the phone using the #00 Phillips screwdriver.
    • Remove the 10 4.0 mm Phillips screws on the back of the phone using the #00 Phillips screwdriver.
    • Not needed, but Tweezers can be helpful in removing the screws from their holes, as their size makes removal a tad difficult.
  8. Starting at the USB port, slide a plastic tool around the perimeter of the phone between the rear housing and frame.  As you work your way around the edge you will feel the clips release.
    • Starting at the USB port, slide a plastic tool around the perimeter of the phone between the rear housing and frame. As you work your way around the edge you will feel the clips release.
  9. Carefully separate the rear housing and the mid-frame to reveal the inside of the phone.
    • Carefully separate the rear housing and the mid-frame to reveal the inside of the phone.
  10. Remove the 2 flex cables shown that attach to the USB board, Tweezers can be especially helpful here.
    • Remove the 2 flex cables shown that attach to the USB board, Tweezers can be especially helpful here.
  11. Gently pry underneath the charging port using the plastic opening tool to separate it from the double sided tape below.
    • Gently pry underneath the charging port using the plastic opening tool to separate it from the double sided tape below.
  12. Once its released, gently lift the main board and remove the USB board containing the charging port.
    • Once its released, gently lift the main board and remove the USB board containing the charging port.
结论
31等其他人完成本指南。
Francis Barnett
于2014年09月23日注册
1,008 信誉积分
撰写一个指南
团队
USF Tampa, Team 9-2, Blackwell Fall 2014 USF Tampa, Team 9-2, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S9G2
5 名成员
创作了10篇指南
if i open the device like this, can i solder cables on the usb port to connect a wireless charging reciever?
Getriebesand - 回复
I was looking for the same solution, and I think it is possible, a closer look at the USB port from various spare parts suppliers, I was in doubt if mine would look the same as the one displayed here, after disassembling my phone, it turned out to be this one: http://bit.ly/1GR4SzP
And it is possible, when messuring connection points, it turns out CN2 on the bord is the +, and - you can fit onto the side of the USB connector itself.
Kenneth H. Nielsen -
I have created a Guide describing the addition of wireless charging, it is in no way affecting the phones stability.
Works great with the S4 mini I9195 LTE version, but mind the different spare part (as linked above: http://bit.ly/1GR4SzP).
megaoetzwuchst - 回复
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 8
过去的30天: 54
总计 24,137
