跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy S4 Mini Charging Assembly
你所需要的
    1. Samsung Galaxy S4 Mini Charging Assembly, Battery: 步骤 1 中的图像 1,1
      • Press and hold the END key to power the phone down.
      询问修复机器人
      添加评论
    2. Samsung Galaxy S4 Mini Charging Assembly: 步骤 2 中的图像 1,1
      • Remove the back cover of the cell phone using a plastic opening tool.
      添加评论
    3. Samsung Galaxy S4 Mini Charging Assembly: 步骤 3 中的图像 1,1
      • Pry the battery out using a plastic opening tool.
      添加评论
    1. Samsung Galaxy S4 Mini Charging Assembly, SIM Card: 步骤 4 中的图像 1,2 Samsung Galaxy S4 Mini Charging Assembly, SIM Card: 步骤 4 中的图像 2,2
      在这个步骤中使用的工具:
      • Using tweezers, remove the SIM card by sliding it towards the bottom of the device.
      询问修复机器人
      添加评论
    1. Samsung Galaxy S4 Mini Charging Assembly, SD Card: 步骤 5 中的图像 1,1
      • Using a nylon spudger, push through the hole at the top of the memory card holder to slide it out.
      添加评论
    1. Samsung Galaxy S4 Mini Charging Assembly, Charging Assembly: 步骤 6 中的图像 1,1
      在这个步骤中使用的工具:
      • Remove the 10 4.0 mm Phillips screws on the back of the phone using the #00 Phillips screwdriver.
      • Not needed, but Tweezers can be helpful in removing the screws from their holes, as their size makes removal a tad difficult.
      询问修复机器人
      添加评论
    2. Samsung Galaxy S4 Mini Charging Assembly: 步骤 7 中的图像 1,1
      • Starting at the USB port, slide a plastic tool around the perimeter of the phone between the rear housing and frame. As you work your way around the edge you will feel the clips release.
      询问修复机器人
      添加评论
    3. Samsung Galaxy S4 Mini Charging Assembly: 步骤 8 中的图像 1,1
      • Carefully separate the rear housing and the mid-frame to reveal the inside of the phone.
      询问修复机器人
      添加评论
    4. Samsung Galaxy S4 Mini Charging Assembly: 步骤 9 中的图像 1,1
      • Remove the 2 flex cables shown that attach to the USB board, Tweezers can be especially helpful here.
      添加评论
    5. Samsung Galaxy S4 Mini Charging Assembly: 步骤 10 中的图像 1,1
      • Gently pry underneath the charging port using the plastic opening tool to separate it from the double sided tape below.
      询问修复机器人
      添加评论
    6. Samsung Galaxy S4 Mini Charging Assembly: 步骤 11 中的图像 1,1
      • Once its released, gently lift the main board and remove the USB board containing the charging port.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
35等其他人完成本指南。
Francis Barnett
于09/23/14注册
1,104 声望
撰写一个指南
团队
USF Tampa, Team 9-2, Blackwell Fall 2014 USF Tampa, Team 9-2, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S9G2
5 名成员
创作了45篇指南
4指南评论
if i open the device like this, can i solder cables on the usb port to connect a wireless charging reciever?
Getriebesand - 回复 分享
I was looking for the same solution, and I think it is possible, a closer look at the USB port from various spare parts suppliers, I was in doubt if mine would look the same as the one displayed here, after disassembling my phone, it turned out to be this one: http://bit.ly/1GR4SzP
And it is possible, when messuring connection points, it turns out CN2 on the bord is the +, and - you can fit onto the side of the USB connector itself.
Kenneth H. Nielsen - 回复 分享
I have created a Guide describing the addition of wireless charging, it is in no way affecting the phones stability.
Works great with the S4 mini I9195 LTE version, but mind the different spare part (as linked above: http://bit.ly/1GR4SzP).
megaoetzwuchst - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 64
总计 26,766
