跳转到主内容
修复你的物品
维修的权力
商店
简介
Click here for the official iFixit guide to disassemble the Galaxy S4 down to the motherboard. The guide you are currently viewing is archived here for historical purposes only.
配件
没有特定配件。
  1. Peel off back of phone Peel off back of phone Peel off back of phone
    • Peel off back of phone
  2. Remove battery. Remove battery. Remove battery.
    • Remove battery.
  3. Remove all 8 screws
    • Remove all 8 screws
  4. Remove Speaker using a thin rigid plastic thing, starting from where the battery nail-hold is located. Remove Speaker using a thin rigid plastic thing, starting from where the battery nail-hold is located.
    • Remove Speaker using a thin rigid plastic thing, starting from where the battery nail-hold is located.
  5. Release clips on the outer rim Release clips on the outer rim Release clips on the outer rim
    • Release clips on the outer rim
  6. Remove clip off of USB port with a flathead screwdriver. Remove clip off of USB port with a flathead screwdriver.
    • Remove clip off of USB port with a flathead screwdriver.
  7. 打开所有标签
    Mac的RAM升级套装
    购买套装
    所有选项卡都有足够的 RAM
    购买套装
  8. Use a platic knife or flathead srewdriver to gently unplug the cable. Use a platic knife or flathead srewdriver to gently unplug the cable.
    • Use a platic knife or flathead srewdriver to gently unplug the cable.
  9. Use your flathead screwdrive to carefully detatch the Touch and Homescreen Flex cable Use your flathead screwdrive to carefully detatch the Touch and Homescreen Flex cable
    • Use your flathead screwdrive to carefully detatch the Touch and Homescreen Flex cable
  10. Remove the cable Remove the cable
    • Remove the cable
  11. Detach the flex cable Detach the flex cable
    • Detach the flex cable
  12. Completely remove the flex cable Completely remove the flex cable
    • Completely remove the flex cable
  13. Remove the usb complete port
    • Remove the usb complete port
  14. Remove the 3G and GSM antenna cable from the motherboard. Remove the 3G and GSM antenna cable from the motherboard.
    • Remove the 3G and GSM antenna cable from the motherboard.
  15. Lift ports from motherboard Lift ports from motherboard
    • Lift ports from motherboard
  16. Detach this port from the motherboard Detach this port from the motherboard
    • Detach this port from the motherboard
  17. Disconnect main screen cable Don't forget to remove this screw.
    • Disconnect main screen cable
    • Don't forget to remove this screw.
  18. Now you can take off the motherboard
    • Now you can take off the motherboard
结论
8等其他人完成本指南。
AhsAlexFerguson
于2016年11月01日注册
423 信誉积分
撰写一个指南
This sucked so baaaaaaad.
AhsAlexFerguson - 回复
I found it helpful, though you're right that it could use a lot of work.
You neglected to mention a screw that holds the motherboard to the display assembly. It can be found to the lower right of the headphone jack and should be removed immediately prior to step 17.
To others who may come along, the USB/daughterboard assembly is affixed to the display chassis with mild adhesive. The daughterboard is VERY flexible and should be removed with caution. I used the flat end of a spudger to gently pry the board up from the chassis by going underneath the cabling on the lefthand side.
Thanks!
E West -
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 3,181
