跳转到主内容
Samsung Galaxy S4 Battery Replacement
你所需要的
  1. Samsung Galaxy S4 Battery Replacement, Rear Case: 步骤 1 中的图像 1,2 Samsung Galaxy S4 Battery Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  2. Samsung Galaxy S4 Battery Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy S4 Battery Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy S4 Battery Replacement: 步骤 2 中的图像 3,3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
    Where is the divot? Please let me know that
    James - 回复
    I purchased a blue plastic opening tool(AKA: Spudge) like the one used in the above Step 1 rear cover pic and found the divot and was able to take off the rear cover as per the “Step 2 “ instructions.
    Terry Crawford, Jr. - 回复
  3. Samsung Galaxy S4 Battery Replacement, Battery: 步骤 3 中的图像 1,3 Samsung Galaxy S4 Battery Replacement, Battery: 步骤 3 中的图像 2,3 Samsung Galaxy S4 Battery Replacement, Battery: 步骤 3 中的图像 3,3
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
    • Remove the battery from your phone.
结论
99等其他人完成本指南。
Sam Goldheart
于10/18/12注册
465,762 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
一条评论
A great super cheap, easy fix for an older phone. Can’t thank you enough. AAA+++
Mark Cosenza - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 29
过去 30 天: 117
总计 87,104
