跳转到主内容
Samsung Galaxy S4 Active Vibrator Replacement
你所需要的
  1. Samsung Galaxy S4 Active Vibrator Replacement, Rear Case: 步骤 1 中的图像 1,2 Samsung Galaxy S4 Active Vibrator Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Samsung Galaxy S4 Active Vibrator Replacement, MicroSD Card: 步骤 2 中的图像 1,1
    • Use a plastic opening tool, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
  3. Samsung Galaxy S4 Active Vibrator Replacement, Battery: 步骤 3 中的图像 1,1
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward to remove it.
  4. Samsung Galaxy S4 Active Vibrator Replacement, SIM Card: 步骤 4 中的图像 1,1
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
  5. Samsung Galaxy S4 Active Vibrator Replacement, Midframe: 步骤 5 中的图像 1,1
    • Use the tip of a spudger to remove the four metallic pads located in each corner of the device.
    • Using a Phillips #00 screwdriver, remove the 12 screws connecting the midframe to the device.
  6. Samsung Galaxy S4 Active Vibrator Replacement: 步骤 6 中的图像 1,1
    • Use the plastic opening tool to pry around the entire edge of the midframe now to release it from the front case.
  7. Samsung Galaxy S4 Active Vibrator Replacement, Motherboard: 步骤 7 中的图像 1,3 Samsung Galaxy S4 Active Vibrator Replacement, Motherboard: 步骤 7 中的图像 2,3 Samsung Galaxy S4 Active Vibrator Replacement, Motherboard: 步骤 7 中的图像 3,3
    • Use the flat end of a plastic opening tool to disconnect the USB board connector.
    • Disconnect the front-facing camera cable connector.
    • Disconnect the earpiece speaker assembly cable connector.
    • Disconnect the headphone jack assembly cable connector.
    • Disconnect the display/digitizer cable connector.
    • Disconnect the antenna cable connector.
  8. Samsung Galaxy S4 Active Vibrator Replacement: 步骤 8 中的图像 1,1
    • Remove the single 2.4 mm Phillips #00 screw from the motherboard assembly.
  9. Samsung Galaxy S4 Active Vibrator Replacement: 步骤 9 中的图像 1,1
    • Remove the motherboard.
  10. Samsung Galaxy S4 Active Vibrator Replacement, Vibrator: 步骤 10 中的图像 1,2 Samsung Galaxy S4 Active Vibrator Replacement, Vibrator: 步骤 10 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use tweezers to gently remove the vibrator.
结论
3等其他人完成本指南。
atika5656
于10/21/14注册
167 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 3,615
