跳转到主内容
Samsung Galaxy S4 Active Speaker Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Samsung Galaxy S4 Active Speaker Replacement, Rear case removal: 步骤 1 中的图像 1,2 Samsung Galaxy S4 Active Speaker Replacement, Rear case removal: 步骤 1 中的图像 2,2
    • Pry the rear case off with a plastic opening tool starting at the divot to the left of the rear-facing camera, near the power button.
    • Lift the rear case with your hands by the corner nearest the divot and remove it from the phone.
  2. Samsung Galaxy S4 Active Speaker Replacement, MicroSD Card removal: 步骤 2 中的图像 1,1
    • Use the flat end of a spudger to press the microSD card deeper into its slot until you hear a click.
    • The MicroSD card will pop out of the slot.
    • Remove the card with your hand.
  3. Samsung Galaxy S4 Active Speaker Replacement, SIM Card removal: 步骤 3 中的图像 1,1
    • Use a plastic opening tool to press the SIM card deeper into its slot until you hear a click
    • The card will pop out.
    • Remove the card with your hands.
  4. Samsung Galaxy S4 Active Speaker Replacement, Battery removal: 步骤 4 中的图像 1,1
    • Insert the plastic opening tool into the notch of the battery compartment near the bottom right corner and lift the battery up.
    • Remove the battery with your hand.
  5. Samsung Galaxy S4 Active Speaker Replacement, Midframe removal: 步骤 5 中的图像 1,2 Samsung Galaxy S4 Active Speaker Replacement, Midframe removal: 步骤 5 中的图像 2,2
    • Using the provided screwdriver, remove the (8) 4.0 mm Phillips #00 screws that hold the midframe in place.
    • Starting on the volume button side of the phone, insert your plastic opening tool into the seam between the display glass and the larger chrome border piece
    • Slide the opening tool along the seam in either direction. Plastic clips will become separated.
    • Once you have pried off all of the plastic clips around the perimeter of the phone, you may remove the midframe from the display.
  6. Samsung Galaxy S4 Active Speaker Replacement, Speaker enclosure removal: 步骤 6 中的图像 1,3 Samsung Galaxy S4 Active Speaker Replacement, Speaker enclosure removal: 步骤 6 中的图像 2,3 Samsung Galaxy S4 Active Speaker Replacement, Speaker enclosure removal: 步骤 6 中的图像 3,3
    • Hold the midframe in one hand and the speaker enclosure in your other hand.
    • Use the prying tool to pry off the silver screen side of the speaker.
    • Use a sharp tool to poke out the speaker enclosure.
  7. Samsung Galaxy S4 Active Speaker Replacement, New speaker replacement: 步骤 7 中的图像 1,1
    • Insert your new speaker, in its enclosure, back onto the midframe.
结论
8等其他人完成本指南。
Miguel Labrador
于09/23/14注册
736 声望
创作了2篇指南
团队
USF Tampa, Team 12-3, Blackwell Fall 2014 USF Tampa, Team 12-3, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S12G3
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,799
