跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Samsung Galaxy S4 Active Midframe Replacement
你所需要的
  1. Samsung Galaxy S4 Active Midframe Replacement, Rear Case: 步骤 1 中的图像 1,2 Samsung Galaxy S4 Active Midframe Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Samsung Galaxy S4 Active Midframe Replacement, MicroSD Card: 步骤 2 中的图像 1,1
    • Use a plastic opening tool, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
  3. Samsung Galaxy S4 Active Midframe Replacement, Battery: 步骤 3 中的图像 1,1
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward to remove it.
  4. Samsung Galaxy S4 Active Midframe Replacement, SIM Card: 步骤 4 中的图像 1,1
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
  5. Samsung Galaxy S4 Active Midframe Replacement, Midframe: 步骤 5 中的图像 1,1
    • Use the tip of a spudger to remove the four metallic pads located in each corner of the device.
    • Using a Phillips #00 screwdriver, remove the 12 screws connecting the midframe to the device.
  6. Samsung Galaxy S4 Active Midframe Replacement: 步骤 6 中的图像 1,1
    • Use the plastic opening tool to pry around the entire edge of the midframe now to release it from the front case.
结论
9等其他人完成本指南。
Geoff Wacker
于09/30/13注册
89,889 声望
创作了89篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 3,421
