跳转到主内容
Samsung Galaxy S4 Active Display Assembly Replacement
你所需要的
  1. Samsung Galaxy S4 Active Display Assembly Replacement, Rear Case: 步骤 1 中的图像 1,2 Samsung Galaxy S4 Active Display Assembly Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Samsung Galaxy S4 Active Display Assembly Replacement, MicroSD Card: 步骤 2 中的图像 1,1
    • Use a plastic opening tool, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
  3. Samsung Galaxy S4 Active Display Assembly Replacement, Battery: 步骤 3 中的图像 1,1
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward to remove it.
  4. Samsung Galaxy S4 Active Display Assembly Replacement, SIM Card: 步骤 4 中的图像 1,1
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
  5. Samsung Galaxy S4 Active Display Assembly Replacement, Midframe: 步骤 5 中的图像 1,1
    • Use the tip of a spudger to remove the four metallic pads located in each corner of the device.
    • Using a Phillips #00 screwdriver, remove the 12 screws connecting the midframe to the device.
  6. Samsung Galaxy S4 Active Display Assembly Replacement: 步骤 6 中的图像 1,1
    • Use the plastic opening tool to pry around the entire edge of the midframe now to release it from the front case.
  7. Samsung Galaxy S4 Active Display Assembly Replacement, Motherboard: 步骤 7 中的图像 1,3 Samsung Galaxy S4 Active Display Assembly Replacement, Motherboard: 步骤 7 中的图像 2,3 Samsung Galaxy S4 Active Display Assembly Replacement, Motherboard: 步骤 7 中的图像 3,3
    • Use the flat end of a plastic opening tool to disconnect the USB board connector.
    • Disconnect the front-facing camera cable connector.
    • Disconnect the earpiece speaker assembly cable connector.
    • Disconnect the headphone jack assembly cable connector.
    • Disconnect the display/digitizer cable connector.
    • Disconnect the antenna cable connector.
  8. Samsung Galaxy S4 Active Display Assembly Replacement: 步骤 8 中的图像 1,1
    • Remove the single 2.4 mm Phillips #00 screw from the motherboard assembly.
  9. Samsung Galaxy S4 Active Display Assembly Replacement: 步骤 9 中的图像 1,1
    • Remove the motherboard.
  10. Samsung Galaxy S4 Active Display Assembly Replacement, Display Assembly: 步骤 10 中的图像 1,3 Samsung Galaxy S4 Active Display Assembly Replacement, Display Assembly: 步骤 10 中的图像 2,3 Samsung Galaxy S4 Active Display Assembly Replacement, Display Assembly: 步骤 10 中的图像 3,3
    • Disconnect the daughterboard connector from the frame.
    • Slowly peel off the daughterboard and remove it from the device.
结论
5等其他人完成本指南。
Justin Ogihara
于09/18/17注册
27,236 声望
创作了52篇指南
团队
EDU Team EDU Team 的会员
Staff
7 名成员
创作了637篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 21
总计 1,895
